P1000 Bumper bolts broke off!!
aauman88
aauman88
1,091
2,846
Long cold chisel and big hammer. Went through hole where winch hawse mounts and beat the tacked nut off back. Pain in the ass for sure. Once got bumper off I removed all the nuts and just went with new nuts and bolts not welded to frame. It’s a pain to get nuts on though so I am going to attach some good ones to frame next time bumper is off
DevinCoulon
Louisiana
Awesome. Thank you for speedy reply. Helps a lot!
JiminAZ
JiminAZ
101
184
Phoenix, AZ
Old thread, but I'd be tempted to run the remainder of the bolt forward through the nut (assuming it wasn't terribly deformed)
Or if I drilled I'd use a left hand drill which would likely grab and back it out. If that didn't work then a bolt extractor (depending on what I could fit in there).
Also I'd think about grade 5 replacement bolt instead of grade 8. Grade 8 doesn't like shock loads.
aauman88
aauman88
1,091
2,846
Problem is it bolts from the outside and without all four entire bolts out you have no access to inside because bumper won’t come off
JiminAZ
JiminAZ
101
184
Phoenix, AZ
I think you could access from the outside with a left hand drill bit. and then an extractor if the bit didn't grab it.
Something like this - with the broken stud pre treated with a nice dose of Kroil or PB Blaster and maybe a little heat. Then whack the broken stud remnant with a center punch to both break it lose and create a start point for the drill.
aauman88
aauman88
1,091
2,846
Yeah very possible and worth a try. The stock bolts are s*** and mine broke off at an angle with the threads stretched. I tried everything before knocking the nuts loose inside. I do plan to have the new nuts tacked to the inside next time I have bumper off and use better bolts
61,495
You don’t want stock Honda bolts. They are very soft. If you can get one out go March it up at hardware with a grade 8 or better. I put standard bolts and tacked the new nuts in.
I agree, just went through this; broke 3 of the 6. Go with better hardware.
jemartz1990
17
10
Landisburg, Pa
Appreciate the advice I'll be going today for new bolts. I got 3 outta the four top bolts in after a good amount of effort. The last bolt I couldn't for the life of me get it hand threaded in. It was difficult by myself to get the winch mount and bumper lined up. Needless to say the last bolt I never got threaded and beat the threads. Thanks for the advice on new hardware.
