P500 Charging battery
F
Fischer
209
321
The woods
I was looking for opinions on charging battery. I bought a battery tender and was wondering if it better to remove battery from the machiene or just hook the tender to the terminals, or does it even matter? I know the manual says remove however, Ive also read from the noco manual you can charge without removing.
Todd627
Todd627
56,298
615,162
MI
You can see where I mounted mine on the right side of the dash.
E69672C8 A6F9 4848 8DB4 37C6562A35B9
snakeriver
272
596
Clarkston Wa
Mine has a quick disconnect so I leave it attached to the battery, and unplug it when I use my 500. I run the plug in cord through my steering wheel, sometimes old folks forget stuff.
SILVER_ALERT
SILVER_ALERT
HONDA SXS Club Flounder
2,885
19,431
Route 66 Oklahoma
I have a "Battery Tender Plus", It came with a Lug Harness that you attach to your battery and just let it dangle outside the battery box. Easy to get to, and cheap. I bought a couple of xtras for the 4 wheelers. About 7 or 8 bucks on Amazon.
Todd627
Todd627
56,298
615,162
MI
Thanks to everyone for the ideas and responses, I believe I got it figured out how I'm going to do it.
Pics or it didn’t happen 😜
Reactions: SILVER_ALERT
11,322
84,119
The winner is...
Anything that works best for you. Good luck.
F
Fischer
209
321
The woods
Bottom line, everyone won by getting me to think about the different mounting spots and techniques used. This site helps alot to get different ideas from all of You dripping stallions! HaHa!
Olaf
Olaf
31
51
Mn
I went on Amazon and ordered an SAE cable mounted it behind the passenger seat, very convenient to charge.
20200705 151213
Reactions: Fischer
