P500 Charging battery
11,321
84,117
Do you know what mode to charge stock batteries on? Regular 12 volt or 12volt AGM.
Should have this AGM. Note charging info bottom left.
F8E51649 FDCD 4FF7 8AA2 1B0CDB501D90
F
Fischer
209
321
The woods
Yes mine is the ytx 14 BS. Already charged it on regular mode. On mine it doesn't say AGM on it so I figured it was a regular battery. Hope I didn't shorten the life of it too bad. Even the one you showed doesn't say it's a AGM, so I did more research, and the model you have and the ytx are both AGM. Wish they would label them on the batteries, but they dont.
Reactions: Mudder
11,321
84,117
Where might one find this socket? My Google-Fu isn't strong enough to find it.
Make sure your plug socket matches the brand, mine shown is a CTek.
Bruce4795
112
248
Arizona
I have a "Battery Tender Plus", It came with a Lug Harness that you attach to your battery and just let it dangle outside the battery box. Easy to get to, and cheap. I bought a couple of xtras for the 4 wheelers. About 7 or 8 bucks on Amazon.
That is what I do also.
