Check engine light
Dg810
Oklahoma
I have a 2019 talon x. I started it today and when I hit throttle it acted stuck and then took off, but when I let off throttle it stayed at a high idle (5,000 rpm) now check engine light is flashing. I believe 10-2 . What could be the issue? I haven’t drove in a couple months but started from time to time and let run for around five minutes. Battery seemed pretty weak today.
Reactions: TripleB
906UP
906UP
13,014
121,328
da Yoop
I don't see a 10-2 in the list, there is a 102-1 that sounds like what you have going on. See below....... and welcome to the site
Dg810
Oklahoma
That could be the culprit!! Gonna check tmrw and let ya know!!
Dg810
Oklahoma
Sorry it took so long to get back with you .. I ended up changing the throttle angle sensor and the check engine light cleared but talon would still rev to 5,000 rpm when started! So I went to throttle body where the throttle cable goes in and I removed that black cover and there was mud in the housing keeping the throttle from returning to normal position!! Thanks for the help guys!! I really appreciate it!!
Reactions: TripleB
