P1000 Chinese line lock junk!!
drfubar
drfubar
TheDonFather
5,889
19,242
Mary's Ridge (Dayton Mtn), TN
@drfubar I gotta run by and grab that bed extender. I'll drop off a kit so you can match yours up at your convenience. I don't remember which one I used. There's only like 20 or so different sizes in there (it's a really good kit lol).
Well, if you didn't work during the week I'd run the extender and the bumper back over to ya. Tiger left the bumper and the extender doesn't fit the 3 seater...;)
Reactions: Delton
Delton
Delton
Honda Fanboy
9,967
31,488
Middle TN
Aw man his bumper didn't fit?? Well that sucks. Is it just the mount measurements that are different? If so, I'll do a quick measurement and modify the mounts.
drfubar
drfubar
TheDonFather
5,889
19,242
No no. The extender didn't fit my sxs. He just forgot the bumper
Sent from my SAMSUNG 7 Active using Tapatalk
Reactions: Delton
Before y'all run out and lynch the first Chinaman you run into, there's a very easy fix. Nothing wrong with the lock mechanism just the crappy Orings that came with it. The fix is less than a dollar. I replaced mine and it's totally leak free. If it does happen to start leaking again, then I'll jump on the "Chinese junk" bandwagon lol. If you kept up with the original box and packaging, there's a spare Oring in it. DONT use that one. Take it to hardware store and use for sizing.
Awesome!! I have a new one coming I'll pull it apart and replace before I put it in.
Reactions: Delton
Don't use hardware store o-rings. They are typically buna-n material. You need an oring rated for brake fluid. Buna is not rated. That is why they are leaking how they are.
Use an oring of the following material "SBR", "Neoprene", "Silicone"
Edit: Hit up mcmaster-carr, measure your oring and order the minimum sized package. Mail to all your friend with the same crap part. If I owned a line lock, That i exactly what I would do.
f***'n A... Thanks for the info!!
Neohio
Neohio
Beast of the East
17,959
86,682
Painesville Ohio
I looked around online for this part. Looks like you have 2 orings on the stem. One at the threads where the nut threads into the body, and one smaller seal on the stem. The larger oring on the threads will be a little harder to measure up. This should be a "-9xx" series oring for o-ring boss threads. Based on your video posted, i would concern myself with orings on the stem itself before messing with the threaded oring.
Reactions: JTW
Ps.. I guess I gotta let these chiggers go.
Both locks have done the same thing... this one just did it much sooner and with less use.
Reactions: drfubar
Neohio
Neohio
Beast of the East
17,959
86,682
Painesville Ohio
"Use" wont make a difference. The time the seal has been in contact with brake fluid is what will damage it.
Grab your spare seal and put it in a little brake fluid, then come back and check it in a week. I bet it will be swollen.
Reactions: drfubar and JTW
Delton
Delton
Honda Fanboy
9,967
31,488
Middle TN
I honestly can't remember if I swapped out both or just one. It's been a few months so they've already outlasted the originals.
I sure appreciate it! I was about to give up on them... I love the lock but was having major trust issues! Glad to hear this before I put the new one in!
Delton
Delton
Honda Fanboy
9,967
31,488
Middle TN
Yours is by far the worst I've seen so far. Mine just leaked. Yours must've totally blown out. I figured you for a gusher
