P1000 clear gas thoughts
70Bones
70Bones
888
3,779
New Brunswick Canada
ALL gasoline burns at exactly the same rate and same temperature. Yes, indeed, avagas will harm the catalytic converter, O2 sensor, etc. It’s called 100LL for a reason....it’s low lead in comparison to the no longer available previous high octane avgas fuels.
Ummmm, no, all gas does not burn at the same rate, that is why we have octane ratings, the higher the octane, the slower it burns. And around here, the highest octane at the pumps has no alcohol in it, which is the ONLY reason we use it in powersports and and other infrequently used equipment.
Haldog77
Haldog77
NTC's Mafia Enforcer (Ret.)
41,079
352,546
Bossier City, Louisiana
Non ethanol in all my small engines. Honda water pump, Honda tiller, boat motors, portable welder/ generator, and zero turn mowers. I do not run it in my truck. Hehehe that's because it's a diesel.
Reactions: Biteme and TripleB
Bachscar
25
106
Kansas
Ummmm, sorry, but all gasoline DOES burn at the same rate. The ONLY thing that the higher octane does is improve the resistance to detonation. The original high octane fuels were developed for use in the high output aircraft engines developed before and during WW2 which suffered severe detonation problems until the tetra-ethyl lead compound was added to the fuel. Problem solved.
Reactions: Biteme
P
Pilot2016
118
173
Rockhill Sc
Honestly I’m not sure what clear gas is (maybe without ethanol?).
In all my non car/truck applications I run 100% straight gasoline. It’s more expensive but I don’t have fuel problems from ethanol either.
100% AGREE👍👍👍
ANYTHING with a motor from yard tools to UTVs should run CORN FREE gas.
If you do that, they will ALWAYS CRANK .... even after months of non-use.
Ethanol gums up carburetors and fuel lines.
Fuel injection and special fuel line composites have made it tolerable for automobiles and trucks...... maybe some fuel injected UTVs..... but I don’t trust it.
Not even a tankful....
It is hard to find... but well worth the effort!!!!
My 2cents🤣🤣🤣
HondaFan
I have replaced the carburetors on all my small engineers and gummed up the works on my Pioneer with ethanol in the gasoline. I now buy only ethanol-free gasoline and have had no problems since. It does cost more, but the cost is small compared to all the maintenance you will incur if you use gasoline with ethanol.
HappyCamper
59
103
Wyo
Different fuel blends burn at different rates under the same temperatures and pressures. Absolute fact. All gas doesn't burn at the same rate, there are many, many variables that determine the burn rate of gasolines, and most all fuels for that matter. But, not to argue the point here, non alcohol fuel is better for our engines. I use it in all my gas engines including my 5.0 Mustang. You'll get better mileage from "clear gas" also. On the other hand, the higher the alcohol content of the fuel the greater the power available if tuned for that alcohol. That's why we use alcohol in our race cars. We can run ridiculously, crazy high compression ratios (16 to 1) with alcohol and it runs cooler to boot but, we have to use a lot more of it for equal power to gasoline.
Chez-500
Chez-500
NC
Used to run our car on alky just hard on everything but it’s faster!!
Reactions: Biteme
HappyCamper
59
103
Wyo
Yah, power is over the top but it pounds the hell out of bearings at those high compression ratios!
Reactions: Biteme
Harvey
Harvey
7
20
Wyoming
Hi, I own a 1000 5 ride in az. I just purchased 15 gals of the so called clear , this is 100 percent fuel only no ethanol , at it is premium . C attached photo , blue is 110 oct leaded
Reactions: Biteme
BBLASER
159
277
Phoenix
why am I so confused? haha. At pretty much every station I have been to in Az, our choices are 87, 89 and 91 octane. Is 91 considered clear gas?
Haldog77
Haldog77
41,079
352,546
Here in Louisiana it is the pump with the blue handle marked "Ethanol Free" or "Non Ethanol". The fuel I bought today was 87 octane non ethanol. $2.19/gallon
Reactions: Backwoods
P
Pilot2016
118
173
Rockhill Sc
Some may call it Clear Gas.
Has nothing to do with octane level.
Look for ETHANOL FREE.... and it will be well marked on the pump and the handle will be a different color. Our QT station here in SC has Red Handles.
There are only 2 places out of 50 around me that carry it.
Well worth the effort to find it.
lee
lee
Village Idiot
2,411
13,650
Springfield Ohio
Clear gas is a reigional thing, its a marketing ploy right up there with putting more chrome on a pickup and claiming it's the best.
For thouse that haven't seen, an image off the web:
20200430 062637
That being said, I use whatever is cheap as per the owners manual.
87 octane was $1.04 yesterday.
This corona thing keeps up any longer and gas will be free.
Boss0144
137
147
Commerce Township, MI
In my area it’s often called ‘rec (recreation) fuel’ or ‘rec 90 (90 octane)’
Reactions: Haldog77
HappyCamper
59
103
Wyo
So what is the antiknock component in "clear" gasoline
It's the Octane. Regular fuel has less octane than premium and fuels containing alcohol are generally lower octane fuels with the added alcohol used to retard the preignition instead of higher octane content.
Snidley
Athena
What octane of fuel should I use in my 2020 honda pioneer 1000? I have used ethonal free gas for years in my small engine machines. I was told I shouldn't use it in pioneer 1000
TripleB
TripleB
16,313
147,698
Caryville, Tennessee
I run regular 10% ethanol and ethanol free. Just depends on what I have at home or what the gas station has. 2 years old this month and 4600 miles and zero issues with gas. I run only ethanol free in anything with a carburetor.
Reactions: 500oneer
Vikes79
Vikes79
SKOL!
11,879
114,659
South Dakota
  2. Talon X4 LV
octane doesn’t so much matter in your pioneer.
Can you run Ethanol blended fuel....yes you can....should you?
I won’t because it’s notorious for gumming up every thing if left for long periods. I’ve fixed way too many small engines and motors because of the stuff.
I’ll even run straight gas in my vehicles if the difference in price is close enough as straight gas yields better fuel economy in my vehicles.
