P500 Clockable winch
So Superwinch advertises their winch as being clockable.. however I found nothing in the directions or online to say exactly how.
Now, it was late and I screwed up royally...
On the Superwinch Terra 35 there are two Allen bolts you take out on the contact end BUT DO NOT REMOVE THE END COVER FROM THE WINCH!!! Simply rotate the cover to one of the 4 desired locations.. I REPETE do not remove the cover as you will be holding the cap that 4 brushes are attached to.. Usually no big deal.. but this is a sealed winch. 2 hours later and a lot of Afro engineering I got them back on the commutator. It's a simple thing to do and no big deal IF you know that the end cap with the electrical connections for the winch have the brushes connected to it!! Unfortunately I didn't take any pics.. but from the pics below you can see what I mean. Hopefully this helps some poor bastard down the road when they're googling how to rotate the contacts on a clockable winch!!!
Ps.. the last picture shows something like what's attached to the contact cap. The brushes are spring loaded and a MAJOR pita to get back on the commutator (that's the part that looks like a drill head).. Maybe I don't have the right tools for the job or just don't know what the hell I was doing but it's an easy mistake to make if you rotate your winch contacts!
IMG 0874 IMG 0873 IMG 0875 IMG 0876
Gator
Gator
The Most Unknown Member
2,488
10,464
Louisiana
I feel your pain. I bought a cheap winch from someone on this forum. During installation I discovered it wasn't "clockable". I had to drill and tap new holes to keep the terminal from resting against a bracket. Sadly, 90° was no better so I had to do it twice. I dropped the brushes the first time.
Reactions: JTW
ehart814
ehart814
1,655
3,645
NWPA
Good to know!
However, I didn't see any reason to re-clock my Terra 35. I've had it on there a while now, and used it a couple times with no issues.
Reactions: JTW
Good to know!
The cable location when mounted on the strongmade bumper is better located at 12&6 for protection.
Yeah.. that would suck!!
Good to know!
Mine bolted to the Stronge Made bumper just fine as well, and cables and terminals are protected fine.
I didn't like the 4:30 location of the terminal..It would probably be fine but I felt it left it exposed to being hit and caught on stuff more than if it were rotated to 12 & 6... so I moved it.
