I'm well into my 70's and tech scares the crap outta me. My clutches are dragging 'a bit' and I know if I try a relearn, it'll fail and I'll be stuck with the MT/AT stuck on until the end of time.I'm listening to those above.
I also follow a Honda mechanic blog as well. Relearn is their recommendation - opinion.
So, right or wrong, have been doing it at every oil change, successfully. Probably a couple times just because.
Have heard it "helps with clutch wear"?
Can't say it's really anything noticeable.
Sometimes it seems the shift pattern is relearning how I drive, but I could have read this too.
My rig is stock.
Edit - I do have the fix what ain't broke tendency.
Cheers!
JDO
Mine was creeping when in gear and was hard shifting from H or L into P. I did a clutch relearn and it worked great. It won't move without throttle now. 14K km and I only did a relearn the one time.I'm well into my 70's and tech scares the crap outta me. My clutches are dragging 'a bit' and I know if I try a relearn, it'll fail and I'll be stuck with the MT/AT stuck on until the end of time.Give me real carb jets and clutch linkage that I can adjust for free play and I'll live happily ever after. I HATE TECHNOLOGY ...
I try to shift into Low when I'm barely rolling, like one mph, especially when cold. It's kinda like double clutching an old transmission without syncros. Obviously, this won't work if you're stuck but that's rare for me.Mine is hard to get into low sometimes. If it won't engage, I move the lever back to neutral then try it again and it will go into low. May have to do this a couple of times to get it to engage in low.
Maybe a relearn would help. 🤔
Exactly. It's like changing gears on my old Allis Chalmers tractors. Slow roll to get the gears lined up and goes right inI try to shift into Low when I'm barely rolling, like one mph, especially when cold. It's kinda like double clutching an old transmission without syncros. Obviously, this won't work if you're stuck but that's rare for me.
I thought if the clutch was allowing input to spin with more force, going in and outta gear may be troublesome at timesI'm no expert but a clutch relearn should have nothing to do with high, low, reverse. Separate gear box
I would say this is solid advice, as long as there is no underlying issues.In out experience I've only had a few machines that wouldn't take a clutch relearn with no noticeable issues before servicing.
If the unit has know problems (slipping clutches, idling problems or stalling) then it'll probably not take. But the other issue needs to be addressed. Clutch relearns won't ever fix anything except maybe a unit that creeps in gear but it could be too late for that as well if the unit has been doing it for a long time.
Almost all of those issues have been fixed by replacing the PC Solenoid due to debris in the oil. Those units have all been abused or not had the oil/air filter changed regularly and the inside of the engine was terribly dirty. But in hindsight, those unit exhibited a very similar clutch takeup when applying throttle; very abrupt and almost hard to ease into the throttle and pull way from a stop without a jerk or stalling.
The 1 other unit was a Pioneer with a weird idling issue where once the clutch relearn was initiated the idle would increase and freak the pcm out. It just ended up needing a PCM reset due to a IACV that was trying to correct for fouled plugs and had burnt that into the PCM.
We've been suggested by Honda to do them every oil change, think of it like adjusting the clutch lever freeplay on a manual transmission atv or motorcycle.
In the event it won't take, you can shut the unit off and drive it like normal with at/mt on, it'll operate normally.
If your having difficulty shifting between gears, then it's possible the clutch is "stuck" somewhat and applying drive force to the sub trans. This is especially more noticeable going into low
A relearn seems to fix it most time
