P1000 Clutch Slip
P
PERK29
6
5
Wasaga Beach
I have done 6-7 clutch re-learns on my 2020 1000-3 and it does seem to take? Now it has both MT/AT on the panel? Do I have a burned out clutch?
Reactions: Lady01
Gabbas
Gabbas
280
701
Humboldt, Iowa
You should see a "-" where it usually displays your gears. It should have a blinking sequence of short then long flashes. Count the flashes and then look up the code accordingly.
Sent from my Pixel 4 using Tapatalk
Reactions: Lady01
P
PERK29
6
5
Wasaga Beach
I do not have a code error, it was just not shifting properly so I tried to do a re-learn. after it was just doing a continues blink and the MT/AT are both lit up on the panel?
Reactions: Lady01
Pilotadam
Pilotadam
326
735
Pell City, Alabama
Does it shift good on every other shift? Or are all shifts the same level?
Did some one drive it with the engine revved up with out the tires spinning?
Sent from my SM-G781V using Tapatalk
Reactions: Lady01
Gabbas
Gabbas
280
701
Humboldt, Iowa
Ok, well that "continuos blink", turn the key off and then on, count the blinks long then short. It should be that way if not, did you have it warmed up properly when doing the clutch relearn? It's important.
Reactions: Lady01
P
PERK29
6
5
Wasaga Beach
it takes off slow then some gears move through normal and some rev high then change, yes I got stuck in some clay and the wheels where not turn and motor revved a bit before I stopped and got pulled out.
Reactions: Lady01
HondaTech
What is displayed in the gear position after it fails a relearn?
If its a "U" small or large, its not warm enough yet.
Reactions: Lady01
Pilotadam
Pilotadam
326
735
Pell City, Alabama
Sounds like you burnt 1st,3rd,5th and reverse gear. There is a good write up by a member on the forum on how to change them. Takes a couple hours, it's not too hard. Takes longer to clean the bike up and remove the rear floor. I had to do mine last summer.
P1K5Dave
P1K5Dave
2,245
8,426
Petoskey, MI
Yeah, when my 1-3-5 clutch pack was bad, it displayed AT and MT and I couldn't make a re-learn go thru.
Once the clutch pack was changed out, relearn worked on the first try and AT went back to normal.
Reactions: Lady01 and TripleB
P
PERK29
6
5
Wasaga Beach
ya I maybe need to take it for a longer ride and warm it up bit longer, I will try that.
after the fail it goes back to P, but both MT/AT stay.
Reactions: Lady01
bigshoe
bigshoe
422
1,427
Pay attention to what gears its slipping in 1 3 5 is all on the same pack sounds to me like u burnt up a clutch pack. relearn is not going to fix it.
Reactions: Lady01
P
PERK29
6
5
Wasaga Beach
Ya it sounds like that is the case as it is slow to take off in 1st gear and then 3rd gear revved high then goes, but I think that is it. Reverse is slow to start as well.
Reactions: Lady01
