Commander XT shocks
Vato
Vato
180
159
I don't think they work as well for the commander application as they do for the pioneer
Sent from my SAMSUNG-SM-N910A using Tapatalk
LOL! I have to agree!
7,608
31,549
  2. 1000 6 Crew
  3. Talon X
  4. Talon R4 LV
Anybody thought about the 700 shocks on the 500 since they're a little bit lighter
7,608
31,549
  2. 1000 6 Crew
  3. Talon X
  4. Talon R4 LV
Looks like there is still a set of XT shocks on the Commander fourm. The guys name is nick1993
Reactions: Tflynn
SundayRdr
SundayRdr
575
1,179
McMinville Tn
Buyers be ware I went back and forth with him over a month about those shocks and it was always something different every time that I spoke to him about the shocks!! Use info how u may and good luck.
7,608
31,549
  2. 1000 6 Crew
  3. Talon X
  4. Talon R4 LV
I forgot you warned me about him.
mrichard
0
US
A guy guy is looking to sell me a set of 4 shocks off a 2014 Commander XT 1000 but he says his Springs are black not yellow does anybody know what the difference is and if these will work on my 700
Sent from my XT1030 using Tapatalk
SundayRdr
SundayRdr
575
1,179
McMinville Tn
From what I read based off of part numbers those will be a std shock & spring but I would request the 8 digit part number that is stamped in the shock on the lower portion of the shock body example : 706200780. The 2011 1000 xt which is what I have front shocks are stamped 706200782 (xt yellow model in the notations of parts list). Get the numbers and go from there.
2011info www.cheapcycleparts.com/oemparts/a/cam/500b66c7f8700228ecf5a0dd/front-suspension
Reactions: joeymt33
G
green02crew
158
54
The only difference I found between springs when doing my research was the color.
7,608
31,549
  2. 1000 6 Crew
  3. Talon X
  4. Talon R4 LV
Look what can in the mail today!!!! 2d117f8fd2274af7fcba5dd9ffa401d6
Looks like I have something to do next week if I can work it in between the honeydos.
Reactions: Tflynn
7,608
31,549
  2. 1000 6 Crew
  3. Talon X
  4. Talon R4 LV
Going to use 4 per shock. If I can trim them. If not I will replace the fronts with new and have tube made to fit
7,608
31,549
  2. 1000 6 Crew
  3. Talon X
  4. Talon R4 LV
I was not happy with the rubber ones that were in the shocks I bought. I actually removed the best 4 and put them in the fronts before install. It's that OCD thing.
Gator
Gator
The Most Unknown Member
2,489
10,470
Louisiana
I got mine to Tram. Let us know how you cut them. I'm pondering different ideas.
7,608
31,549
  2. 1000 6 Crew
  3. Talon X
  4. Talon R4 LV
OK got a skeet shoot at my place planned for this weekend coming up, so I will hopefully have time to work on it this week.
7,608
31,549
  2. 1000 6 Crew
  3. Talon X
  4. Talon R4 LV
Yeah I called him back right after I placed my order and he threw in it cup of that lube
Gator
Gator
2,489
10,470
Louisiana
Anything special about the grease? I didn't look close but I don't think there was any in the box.
Axle Grease?
Gear Oil?
Johnson's Jerking Lotion?
7,608
31,549
  2. 1000 6 Crew
  3. Talon X
  4. Talon R4 LV
I'll check when I get home, think it is special. Polyurethane is not compatible with all typed of lubricants. It's in an cup about the size of a 35mm film canister
G
green02crew
158
54
Axle Grease?
Gear Oil?
Yes, it's special.
HondaPower
39
32
I bought the shocks from nick1993 they were in really good shape. The bushings look good. Put the fronts on. Raised the front about 2 inches. Now the 30s with the 3 in lift dont rub when going over bumps.
The only issue I have is the rear. I have a 3 in bracket lift on it. If I put on the rear shocks it puts the axles in a real bind. I am either going to have to turn the rear shocks all the way up or remove the lift from the rear and install the xt shocks and turn them up accordingly.
