P1000 Confirmation on second battery that fits! Honda Pioneer 1000
E
Ericthered
Eric The Red
271
522
Sparks, NV
Info please?
The batteries I bought are: Two Featherweight Lithium Battery, 12V 72WH 360 CCA. You will have to use a dremel tool to nibble off ribs inside battery compartment. I put the two back to back. Over a year and no issues. Both have charged just fine with the True Charger Relay.
If it’s convenient could you post a picture of that?
BigOL3
BigOL3
2,997
8,920
Could you post a link?
Reactions: BWAF
NFA_Fun
NFA_Fun
82
96
Pinetop, Arizona
I have looked into the batteries posted above and crossed referenced all of them, then crossed referenced those results. Most seem to come back to a host battery UB12350. Seen them priced from $49.99 to 159.99....depending on what brand name sticker was on it. Reviews were mostly positive. The negatives were failures around a year, brands being misrepresented, and those stupid people that screw something up and blame the manufacturer.
Going to go look at a few of them in the different stores and compare. Will post up my findings.
Only looked at this thread to buy a battery.....now look what happened
A
Ar200
Arkansas
A6677A48 6359 49D2 943E F0C5C2DA2837
Is there any reason this battery wouldn’t work for a dual battery? 26 ah is it ok for it to setting like that? I think it’s just like a mighty max just slightly smaller.
Reactions: BWAF
NFA_Fun
NFA_Fun
82
96
Pinetop, Arizona
Interstate SLA 1156 or Interstate DCM0035 AGM on their side fits. I have the DCM0035 AGM in mine and the mighty max is collecting dust.
35 AH as well.
Did you have to do any modifications to the factory box to make it fit? Just picked up the DCM0035 and based off measurements it’s going to be tight.
Project this weekend get battery, isolator, and winch installed.
Reactions: BWAF
aauman88
aauman88
1,091
2,846
Would putting two of the DCM035 in machine be good or no? Is it only good as a secondary battery?
Reactions: BWAF
208,786
W
I gave the interstate dcm0035agm a try. Works great for me. Not sure how it would hold up to heavy winching. But I had the soundbar cranked up and light whips running for two hours and the voltage on the interstate never got below 12.6 volts. Picked mine up local for $116 with no core exchange.
What I was told by Warren Winch was there ATV winches aren't designed to run but a few seconds at a time and you need to let them cool?
Reactions: BWAF
mtrbike
15
Atlanta Michigan
Interstate SLA 1156 or Interstate DCM0035 AGM ...
Could somebody help me wrap my brain around how a 7.75 battery flipped on its side,
will fit into the second battery location?
im not seeing it as the length is still too long, what am i missing ? as i really like the 35ah
Reactions: ChadD and BWAF
NFA_Fun
NFA_Fun
82
96
Pinetop, Arizona
The battery box measures 6 1/2” x 5 1/4” at the bottom. The battery measures 6 1/2” x 5”. On its side, you can go 10” tall.
Will be installing mine on Saturday. Will post up some pictures after it’s done.
Reactions: ChadD, BWAF and JTW
NFA_Fun
NFA_Fun
82
96
Pinetop, Arizona
The SLA has the battery posts that stick up. The DCM is a higher quality (was told) and the post are flush with the top. Nothing protrudes past the top of the battery.
Reactions: BWAF
Dirtstiffs-1000
Dirtstiffs-1000
1,699
6,153
hondasxs.com
20190217 130439
Yuasa GYZ32HL - 500 CCA, 32AH
www.yuasabatteries.com/battery/gyz32hl/
Had a new spare for a bike sitting around, thought I'd try it.
Fit great by using the 1/4 " styrofoam packing around and under it to keep it from moving.
It's a workhorse of a battery.
Jim
Tramguage1
Tramguage1
Texan
7,528
30,968
Somereset, Texas
  2. 1000 6 Crew
  3. Talon X
  4. Talon R4 LV
Well my Odessy died ! Purchased 11/17
Going to try and see how well I can do with warranty replacement. (2yrs)
Let's see how it goes.
If not I'm going to try another brand this time.
