P1000 Confirmation on second battery that fits! Honda Pioneer 1000
208,786
Well my Odessy died ! Purchased 11/17
Going to try and see how well I can do with warranty replacement. (2yrs)
Let's see how it goes.
If not I'm going to try another brand this time.
Did you buy online? I buy all my batteries at Battery Outfitter a local brick and mortar store local and they have always treated me well, personal and business wise. And they build custom batteries for all kinds of stuff, like pipe locating equipment. I took a battery out of our locator to them, the guy says they don't stock that battery and it would be a special order or he could build one for $ 38.00, cheapest I could find online was $ 78.00
Tramguage1
Tramguage1
Texan
7,528
30,968
Somereset, Texas
  2. 1000 6 Crew
  3. Talon X
  4. Talon R4 LV
Yes Amozon, that wont happen again!
Reactions: ChadD and BWAF
Tramguage1
Tramguage1
Texan
7,528
30,968
Somereset, Texas
  2. 1000 6 Crew
  3. Talon X
  4. Talon R4 LV
Went with the Interstate DCM0035
Had to make a slight modification to the battery box. But hoping this last more than 17 months. If this doesn't work, a full size under the seat is the next choice.
20190729 182409
I also installed my Bluesea fuse box. Now to clean up the wiring and get ready for Colorado!
Cw733
9
16
SC
What did you end up having to do to the battery box?
Reactions: BWAF
Tramguage1
Tramguage1
Texan
7,528
30,968
Somereset, Texas
  2. 1000 6 Crew
  3. Talon X
  4. Talon R4 LV
i used a Dremel tool to cut a relief in all 4 corners of the battery compartment. This allows the sides to expand just a little. This allows the slightly larger Intestate battery to be wedged in there. You wont need a hold down strap!
ehart814
ehart814
1,700
3,873
NWPA
I ended up buying the $55 Mighty Max battery on amazon. Supposed to be an equivalent to the Odyssey battery. One year warranty. I figure I can go through three of these for the price of one Odyssey...
TripleB
TripleB
16,419
148,738
Caryville, Tennessee
Me too. NOT THE MOVEMENT!
Reactions: Mudwing
Cw733
9
16
SC
I think the battery slots may be different between year models. I got the DCM0035 and there was no way it was gonna fit upright. Was a good inch too wide. Does fit pretty well on its side. I have a 2016 Deluxe.
208,786
Dry batteries doesn't mater how you mount them?
SlowPony46
45
68
IL
Can anybody confirm whether the Might Max YTX30L-BS battery will fit?
Schmeg
Schmeg
187
394
Bangor Maine
Reactions: ChadD
Cuoutdoors
Cuoutdoors
Executive Member
4,229
15,541
Central Iowa
View attachment 110144 Is there any reason this battery wouldn’t work for a dual battery? 26 ah is it ok for it to setting like that? I think it’s just like a mighty max just slightly smaller.
That looks to be the same shape as the odyssey battery. I'd spin it around and put the terminals to the front.
Elvis8310
Elvis8310
54
103
Edmond, Oklahoma
The batteries I bought are: Two Featherweight Lithium Battery, 12V 72WH 360 CCA. You will have to use a dremel tool to nibble off ribs inside battery compartment. I put the two back to back. Over a year and no issues. Both have charged just fine with the True Charger Relay.
What is battery number, WPS Distributor so can get them at wholesale
208,786
Bummer!
Dirtstiffs-1000
Dirtstiffs-1000
1,699
6,153
hondasxs.com
Reactions: TripleB and ChadD
