P1000 Coolant drainage out of reservoir
T
Tma
MN
When plowing snow in low range, coolant drains out of reservoir overflow line. It doesn’t overheat and the indicator doesn’t come on. The coolant is not over filled. What would cause this? And what is the solution? Thank you
Dezrik
Dezrik
Follow me for adventure!
297
956
MOAB, Utahhhhhhhh
Are you sure its coming from the overflow? In my case the lower hose on the coolant bottle was leaking because they used a cheap wire clip
Vikes79
Vikes79
SKOL!
11,709
113,610
South Dakota
  2. Talon X4 LV
It’s not really a reservoir, but an expansion tank. How full are you filling the tank? Shouldn’t be much more than 1/2 way if I remember correctly.
Are you sure it’s pushing out the top tube and not leaking out of the bottom?
T
Tma
MN
Filled to the fill line which is half way roughly. I seen it happen. Running through the top tube
  • Wow
Reactions: Smitty335 and CID
Johnny5isalive
Iowa
does it leak through skid plate by oil drain plug?
