P1000 Custom Under seat storage
Remihunt_57x
Remihunt_57x
Gladstone, mi
Well I got my 2018 1000-5 about two weeks ago now and while I was doing some customization; winch, roof and windshield for now, I found this huge empty space under the driver seat. Actually it really ticked me off Honda didn't utilize it for a storage compartment with a door on one of the outside faces. Somewhere like the vertical face where the warning label or behind your legs would be awesome.
So the inner engineering in me came out. This is what I got so far, making a box inside of the compartment with 1/4" hdpe to protect the electric inside and I'm going to be putting a door on one of the faces I was talking about so i won't have to take the seat off in the middle of a mud hole when I need my straps.
IMG 20190716 205829271
Still have to clean up the plastic welds a bit, my welder is starting to take a s*** on me
IMG 20190716 205842897
IMG 20190716 205816832
IMG 20190716 205824229
Tuco69
Tuco69
1,474
7,563
Middle Georgia
Congrats on the purchase. It’s not the most convenient storage but Honda makes a storage container that fits the space. Post pics when you’re done. Like the idea of the door.
Reactions: Lady01
Firemedic530
Firemedic530
386
1,122
West Jefferson, Ohio
Is your box thought to be water tight?
Unless you avoid water and mud, I don't think you can make that area "dry". I originally cut up an old plastic trash can I had and squeezed it in by removing the outer cover below the seat. My second ride in Tennessee, I filled the entire trash can with water.
I now just store 2 50cal water proof ammo cans with my tools under there. They are my heaviest boxes and that keeps the weight low. I unfortunately have to pull the seat bottom to get them out. I don't think JTW door would be big enough for them.
Reactions: Lady01 and BigOL3
39,079
I use the same door that Josh uses and I can get both ammo cans in and out. It took a little practice and it only goes a certain way but I’ll try to get some more info on that when I get home.
Reactions: Lady01
Firemedic530
Firemedic530
386
1,122
I stand one on end and leave the other horizontal. I'm guessing flipping the seat is quicker. I looked at the doors when Josh first posted.
Reactions: Lady01
39,079
If you have a seat with stock seatbelts then it would be quicker but by the time I pull the seat and the heat barrier and have to mess with all three harnesses in the front to put the seat back in it turned out to be easier just to use in the door.
Also sometimes I may have a small cooler in the middle seat or I don’t want to unharness the little one in the middle. At least with the door I’ve got the option to do both ways.
If I can remember I’ll take a quick video of getting the things out and putting them back in.
Tigermark
Tigermark
Outside looking in.
Less talk, more pics!
Yep..
Reactions: Lady01
L
Loren
15
The push latches for the side are just what I have been looking for, where did you get them? Part number please. Nice job, thanks for sharing.
Reactions: Lady01
39,079
