im assuming then u didn't drop a $600 lithium battery in your truck as well - lol...Being a #oleguy and slow adapter, stock Yuasa for me. Lithium's disadvantages outweigh their advantages IMO. Their biggest draw seems to be light weight but I don't care about 6 lbs on a 1900 lb. Talon.
That being said - I was a member on a motorcycle site and an electrical wizard took it upon hisself to test every lithium battery he could find, using his knowledge and very expensive test equipment - his findings showed that Antigravity and EarthX were far and away better than their competitors. He did this for several years before losing interest in the project.
I'm toocheapfrugal to spend two or three times as much for the same function.
I recommend that you change your username to ID-10T. 🤣 Or maybe PEBCAK.Battery dead after 4 years, can anyone recommend a lithium battery?
Thats a good battery. Put one in one of my sleds a while back. Been fantastic even in sub zero temps. Ill get one for my P1 or Talon if i ever need a changeDuracell AGM from Sam’s Club.
How did you know you used the reserve start feature? Is it automatic or do you have to push something on the battery?I use Antigravity with there restart (and it worked the when I've ran my battery to low). I have 3 of them in our Talons and love them so far. I feel they help the electrical system on the Talon. I bought them all from Dell's and had good pricing/service from them.
I will try the AntigravityI use Antigravity with there restart (and it worked the when I've ran my battery to low). I have 3 of them in our Talons and love them so far. I feel they help the electrical system on the Talon. I bought them all from Dell's and had good pricing/service from them.
Yes I pulled the cover real quick and hit the button. It fired right up! @Lil_Steve has the how too covered!!)How did you know you used the reserve start feature? Is it automatic or do you have to push something on the battery?
You won't be disappointed!! I actually think that it helps with the power steering and other voltage dependant things on the Talon. The lithium does not have as much voltage fluctuations when the rpms drop.....at least I am paying attention to it.I will try the Antigravity
