Delton
Delton
Honda Fanboy
9,967
31,488
Middle TN
Only have one day to work on my stuff so I dug up some scraps and made a temporary cart for the tig. Not bad for stuff I dug out of the junkpile.
IMG 20170118 100849755 1336x752
IMG 20170118 122627362 1336x752
IMG 20170118 134429570 751x1335
IMG 20170118 135027027 1336x752
PioneerPete
PioneerPete
1,496
3,517
Chattanooga, TN
Not exactly. There's so many options I don't know where to start. Gonna chop it, that I do know. Not sure how much yet.
I want to come check it out when you fit it up... I'd like to see what all is involved and check out the head room...
Reactions: sharp
PioneerPete
PioneerPete
1,496
3,517
Chattanooga, TN
I was looking at mine the other day trying to figure out how I'd modify the soft mid panel to work with a chopped top...
GlockMeister
GlockMeister
The Bearded Wonder
7,606
35,593
Greenville, Mo
I'd like to chop mine too but haven't figured out what to do with the tip out 2 piece windshield
Reactions: CumminsPusher
322,773
Can't that be cut at top?
322,773
It's got a bend at the top. I guess it could be cut and then heated, re bent ,and new holes drilled
I didn't realize that one was bent top also but makes sense. It sucks because it's got bends at all four corners then. How about taking it from the lower. Cut section from the center and double up the two sections so you retain both bends?
Reactions: Eltobgi and sharp
GlockMeister
GlockMeister
The Bearded Wonder
7,606
35,593
Greenville, Mo
Have thought on that too..But how would you seam the lexan together?
322,773
Well as long as you left three quarters of an inch to an inch on both sides you could do something as simple as double back. As long as the Lexan was super clean you could do capillary glue which is designed for that material and it would be superstrong
GlockMeister
GlockMeister
The Bearded Wonder
7,606
35,593
Greenville, Mo
Ya dunno if I'd like having a line of gray tape to stare at....I'm weird about things lol.
322,773
I added capillary glue which would be clear lol. But also if you scuffed and sprayed the outer piece on the inside it would show black on the visible outside making the lower section look fairly close to how it did.
322,773
We need a solution for this issue. I have the same windshield and I want to chop mine. I'm not as creative as you fellas. ;)
Seriously either would work and look good. Just need to not sweat the small stuff and start cutting
Tigermark
Tigermark
Outside looking in.
I'll have to get Glock or Delton to help, I'm not a welder. Maybe on my next visit to Mary's Ridge we could knock it out.
I'm thinking the chop should be 4" , have to do some more planning.
322,773
4 is a good number stay away from weird stuff
Reactions: GlockMeister
Similar threads
Replies
Views
241
P1K5Dave
V
Replies
22
Views
2K
Replies
Views
2K
