So you will need 2 Ts that have two 1/2" nipples and one 5/8" nipple.
I either cut the wrong hose, or you are mistaken on 1/2". I'm about 98% sure I know which one of us is right, and I'm not sure it's me..... No size is mentioned anywhere in the manual as to what size the hose actually is. it does mention an adapter though, but I don't know if it's necking up or down from the hose diameter....
I may need to do a patch job tomorrow with a coupler and move further back. I don't want the heater to throttle down from the thermostat.
Off the diagram I realise now that that I did cut the wrong area, as the diagram is showing from the REAR not the side as I thought, but I imagine it's the same hose. I don't want to remove the whole floorboard under the bed Cause I'm lazy, but I will if I have to.
Anyways I'm gonna check and see if the hose I cut transitions Into something else. It must somewhere. I just assumed it was the right hose because of the area it was located at, and at the time I thought the diagram was side view. It warmed up with the coolant and was smaller than the radiator hose. Looked too big for 1/2" but thought maybe it was crazy thick walled tubing. It wasn't.
Can anyone tell me with certainty what I cut into, and if I need to patch it and cut somewhere else?
Sent from my Pixel XL using Tapatalk
