DIY Snorkel
Tot
Tot
661
462
Des Arc, Arkansas
That there is a really good idea. I'm not sure how thick my hose is crushed but it's pretty flat. I can measure it if you need me to
That would be awesome if you would. Do you still have the instructions for it? Also is it a 2 inch hose?
Sent from my SM-G900V using Tapatalk
Delton
Delton
Honda Fanboy
9,967
31,488
Middle TN
I don't think I still have instructions. They'd been copied so many times they were almost unreadable anyways lol. I can tell you exactly how the hose mounts plus I have close-up pics on my build thread. I'll measure hose soon as I can. I don't get home from work til around 8 so not sure if it'll be today or not. I get off at 5:30 tomorrow so I definitely can then. Not sure what size hose is at the ends. I seem to remember the PVC pieces being 2" but I'll check just to be sure. All you need are 2 PVC couplings, a 90, and 2 hose clamps and you'll have everything I got. Plus a couple of cable ties.
Reactions: Chuffer and Tot
Tot
Tot
661
462
Des Arc, Arkansas
Do you have any pictures of it before it was installed. I remember seeing some a while back on a thread but don't remember which one. If you don't mind post some pictures of how it connects to the air box
Delton
Delton
Honda Fanboy
9,967
31,488
Middle TN
They're all on my build thread. Pretty sure there are a couple of it right out of the box too. Don't have them on my phone anymore.
Delton
Delton
Honda Fanboy
9,967
31,488
Middle TN
Oops I guess I lied lol. Did still have a couple. This is connection to airbox. Remove factory tube from this connection then remove stock tube from under seat. Then connect snorkel. Easy.
PhotoPictureResizer 160421 130323775 800x450
Reactions: Tot
Delton
Delton
Honda Fanboy
9,967
31,488
Middle TN
Snorkel hose runs behind coils. It's pretty tight but with a little patience it'll go.
Reactions: Tot
Delton
Delton
Honda Fanboy
9,967
31,488
Middle TN
This is how it runs after airbox connection
PhotoPictureResizer 160421 130345489 800x450
Reactions: Tot
Brian321
Brian321
6
Melbourne FL
Pioneer 1000 snorkel
3" aluminum tubing
Pipe lengths:
9 3/4"
2"
4"
5 1/2"
4 3" elbows under hood
Image Image Image Image
Reactions: adnoh
Delton
Delton
Honda Fanboy
9,967
31,488
Middle TN
@Tot those fittings are 2" so id of hose would be slightly larger than 2". The flat part is little less than 2". Probably closer to 1.75". Hope that helps.
IMG 20160425 115405401 HDR 800x450
IMG 20160425 115457745 600x1067
Reactions: Tot
Brian321
Brian321
6
Melbourne FL
Looks good, I just don't want to lose my cup holder.
Never use mine while riding anyway. Just hold it. And plan on buying the rubber cover for the door holder like the 700 has. Already has recess and screw holes
Reactions: Tot
Brian321
Brian321
6
Melbourne FL
3" aluminum tubing
Pipe lengths:
9 3/4"
2"
4"
5 1/2"
View attachment 14172 View attachment 14173 View attachment 14174 View attachment 14175
I only had to cut one of the elbows to have correct angle. The last one that goes up to cup holder. And the scrap piece I used as a coupling above cup holder. Still working on a clean design to run up roll bar. And I turned intake elbow backwards and put the pre filter mesh in it. Not loud. Works great.
Reactions: Tot
Tot
Tot
661
462
Des Arc, Arkansas
Lmao. That's funny. I don't plan on going deep period. Mine is just an insurance policy. It's hard sometimes to tell how deep a creek is. Especially after you get it all muddy lol.
Same here, the places I'm going to be riding have a few water holes so I would rather have it and not need it than to need it and not have it
What happens if you drive in heavy rain?
Sent from my iPhone 10s
