DIY Snorkel
Tot
Tot
661
462
Des Arc, Arkansas
Okay, so I want to snorkel my rig, but don't want to pay the crazy prices. I know some people have built their own. So I'm asking to see pictures of what y'all have, measurements, and instructions on how y'all did it.
However, I'm not going to give up my passenger cup holder.
I'm looking mostly for behind the seat snorkels.
Sent from my SM-G900V using Tapatalk
Bunk
6
San Mateo, Florida
There isn't enough room behind the seat because of all the cross members and frame. There is a kit that has a collapsed hose that you fish up behind the seat.
This is my friends. Cost him about $30.
E81081ce75b47398ab100d090f84195d
Reactions: Rincon
Here's mine, cheap and effective. Make it as high as you want. The only cutting is the hood and it can be replaced easy if you choose to revert back to stock.
668b729aaa01b197df01bb9d6ee22151
Sent from my iPhone 10s
Tot
Tot
661
462
Des Arc, Arkansas
Only problem with that is I have a 2 piece windshield.
Tot
Tot
661
462
Des Arc, Arkansas
I love the looks of yours and have all the stuff in my cart on Amazon, but I think it will be a little much with the Tough Country bumper.
Tot
Tot
661
462
Des Arc, Arkansas
I wish I could find what hose they used. I know which one you're talking about, I just don't want to pay the $205 for it
Delton
Delton
Honda Fanboy
9,967
31,486
Middle TN
Before I installed my snorkel I should've ran to Huntsville AL and visited the Grainger store. I bet those guys could find the hose used in that kit.
Reactions: Tot and joeymt33
Tot
Tot
661
462
Des Arc, Arkansas
I was going around to the hardware stores trying to find some sort of hose to use to snorkel my rig. Came to tractor supply and saw a water pump hose about 2" round. I may get some and try to build a snorkel using it
Reactions: educ8tedguess
Delton
Delton
Honda Fanboy
9,967
31,486
Middle TN
Is it metal reinforced? Hope it works
Tot
Tot
661
462
Des Arc, Arkansas
It has ribs in it, not sure if it's metal or not. I can hardly get the hose to flex squeezing with both hands. I think I'm going to get some next week and see what I come up with
Deer-hunter
Deer-hunter
136
200
Effie,Louisiana
Yes that is the pick up hose for a water pump. It is very stiff so the hose doesn't collapse during pumping. It is metal reinforced. This hose should work for you.
ghost
ghost
993
1,873
BC
I was thinking about using blu-lock irrigation pipe which has thin walls but is very strong. 4 x 1 inch hoses has the same area as a 2 inch hose.
Use a manifold on each side of the tight spot (top and bottom) and 5 or 6 x 1 inch hoses. Maybe someone can turn that concept into a good idea.
I just went and looked at mine to see how tight it would be. With the hard back panel - forget it, unless you want to cut a lot of plastic.
Back to joeymt33's design for me - which I've always liked.
I don.t think the blu-lock pipe would work due to the size of the fittings to build a manifold - but the multiple smaller hose idea might work with some other type of hose.
Reactions: Tot
Tot
Tot
661
462
Des Arc, Arkansas
If I could get it flatten and hold its shape it could work. But I may end up just buying the one from eBay or like Joey
Delton
Delton
Honda Fanboy
9,967
31,486
Middle TN
Maybe the one from tractor supply will work. You may have to experiment with pressure when you try to flatten it. If you can get the metal to bend, I think you'll have it made. I like Joey's design but having something sticking out in front of me would get on my nerves lol.
Reactions: Tot
Tot
Tot
661
462
Des Arc, Arkansas
I've also got the Tough Country bumper on order and I think the snorkel up there would be a little much.
Deer-hunter
Deer-hunter
136
200
Effie,Louisiana
Drive over the hose with your truck with something like a 1x4 on each side so that it won't completely flatten out.
Reactions: Delton and Tot
Delton
Delton
Honda Fanboy
9,967
31,486
Middle TN
That there is a really good idea. I'm not sure how thick my hose is crushed but it's pretty flat. I can measure it if you need me to
Reactions: Tot
