P700 Does your pioneer sit level?
Buurma
Buurma
41
Northcoast
Mine has sat crooked since the day It was delivered, is it supposed to sit level? I was assuming Honda gave it some pre load so when the operator sits it will level out
Tflynn
Tflynn
Not a liberal
2,502
3,844
Northern California
I think it should sit level. Check the preload adjusters on your rear shocks to see if they are on the same setting, if they are on different settings it would cause the machine to lean a bit.
Reactions: Bubbadoyle
Buurma
Buurma
41
Northcoast
They are the same adjustment. I've looked for bent shock mounts, pulled ball joints. Short of calling my dealer I've searched for anything.
Buurma
Buurma
41
Northcoast
But it's the roll cage and all. It's about an inch shorter than the other. If my sway bar was bent that would be my issue.
If it is bent I was going to go to my dealer, I paid for 4 years warranty I'm gonna use it lol
Tflynn
Tflynn
Not a liberal
2,502
3,844
Northern California
Maybe try unhooking the links just to see if that fixes it. If it's the same then you know it's not the sway bar. But you make a good point, if you paid for the 4 year warranty you had better use it. After all it's a Honda, this may be your only chance!!
Simpleman
Simpleman
57
29
Yuba City, California
Is the gas tank full? mine has a slight lean to the passenger side when the tank is full. Just food for thought....also check that your air pressure in the tires are equal left to right....I know this sounds stupid but........
Reactions: Buurma and Tflynn
66,827
Can you push it straight and it stays? Are your wheels pointing straight
Springer
Springer
312
234
Mine 1000 seems to lean to the right, but so did my 700, and Rhino before that. I assumed it was because my barn floor was unlevel. It is a concrete floor, and looks very level until you park a sxs on it.
I did some measuring one day and the passenger side was about 1 inch lower. So I got out the level. The floor was level at the front wheels, but not at the rear wheels. That made it sag slightly on the passengers side.
Try backing it in to the same spot and see if it changes
Hope this helps
Buurma
Buurma
41
Northcoast
When I took delivery the alignment was very of. Wheel had to be about 45° to the left to drive straight. Service department pulled the steering wheel and set it straight.
Fuel is a good idea. I always keep it full.
I have yet to tinker with it.
Buurma
Buurma
41
Northcoast
Update:
I pulled a sway bar end link today. It's not binding. And I didn't have to force it back in its home
All my tie pressures are the same on each side. 10 up front and 12 in rear
I put a level on it (sorry for the blurry photo)
KIMG0744
Springer
Springer
312
234
Hope this helps
I backed mine into the barn just for giggles, and it leaned the opposite way meaning that it is my floor that is unlevel.
Looking at just the floor with nothing on it, it looks perfectly level....but it's not.
Reactions: Tflynn
Buurma
Buurma
41
Northcoast
No matter where I park it she doesn't sit level.
Called my dealer, they can't tell me what to look for besides the same things I've already checked.
In reality if none of my parts are bent/stretched/broken there's nothing I will be able to do under warranty
teejk
15
Hatfield Wisconsin
Your steering wheel was "off" from day 1? So is mine! Guess I'll open a new thread on it.
motorman18
439
277
Laurel, MS
I wouldn't touch nothing take it to dealer every nut and bolt has paint on it if paint is not lined up your warrenty can be void just saying
Reactions: uconn411
teejk
15
Hatfield Wisconsin
Dealer is 50 miles away...in the meantime I see that the problem may not be that rare. The machine "tracks" good, just the steering wheel says it is is 3 o'clock instead of noon.
motorman18
439
277
Laurel, MS
Hey I'm just saying every nut and bolt is painted by honda when that paint is not lined up they know it these big companies don't make money off of warrenty they will try to sh!! You
