P700 Door weather stripping
P
PonchoLejeune
48
29
Louisiana
anyone add some kind of stripping on the bottom of front doors to try and stop some of th dust?
Lynn
Lynn
263
134
Yakima,WA
Yea I'll share some photo's of what I did on my 700 2p. Rear door seal was silicon-ed to the door frame , the front seal was silicon-ed to the door. But what heped the most was putting memory foam around the seat rear mounts where they slide into the holes at the back of the seat. I don't have any photo's of that yet just did it a week ago. I did test it and it made a huge difference.
100 1546 100 1547 100 1551 100 1552 100 1553
Lynn
Lynn
263
134
Yakima,WA
Door seal foam is 3/8" to 7/16 Thick and about 1" wide. The memory foam I used was 3" thick and a 4" square and I cut a small rectangle hole in it and slid it over those protrusions on the seat.
sek-hunter
sek-hunter
317
617
Seems like most of my dust comes from between the seat back and bottom after adding the fabric rear panel. I thought about buying a couple black towels to wedge in there?
Probably need to seal around the doors next.
Lynn
Lynn
263
134
Yakima,WA
Here's some more photo's. The area's around the seat belts can be filled with black landscaping foam. It's made for exposure and works great. DSCN0875   Copy DSCN0876   Copy DSCN0877   Copy DSCN0878 DSCN0879 DSCN0880
