P700 700-4 Hard cold weather starting
BobRack
42
92
Arkansas
Hi folks, I have a 2021 pioneer 700-4 deluxe. Like many here it has been a disappointment with cold weather starting. I have tried the larger battery, plugs, valve adjustment, checking voltage at every point, with no improvement. After I did the valve adjustment, first time, 700 miles and way loose, I attempted to start it. The usual happened lot's of cranking, no start. I pulled the plugs thinking it was flooded but the plugs were dry. So I tried 1/4 pedal and cranked it over about 4 turns, let off the key and released the pedal and cranked it again and it fired right up. I have been cold starting it this way since and it has worked great every time, 17 degrees F out this morning and it started right up doing it this way. Anyway hope it helps someone else.
I've actually been trying to use that method for awhile. But just hasn't been cold enough. Several mornings it's been in the 20's and it seems to help. I also finally had to replace the battery which also helped. But I think there is something to this.
