P1000m5 Dragon21's build
Dragon21 submitted a new Garage Item:
Here We Go Again... 1000-5 This Time
Well, now that the 700-4 is gone and the 1000-5 is home. its time to get started on the build again. I really try to go slow and pace myself. however that doesnt always work that way. When i got it, it had roof and windshield as part of the deal.
Ordered a winch and mount, synthetic rope and fairlead for it, HL snorkel, Amazon switch plate, fuse box, 100amp disconnect.
still plan to get a honda front bumper, lightbars, and soundbar.. when money permits.
debating about dual battery setup... not sure if ill do that or not. I dont tend to use radio or lights when its not running.
Call superwinch and see if they'll warranty it... warn did for a couple of the guys. If superwinch will do the same that would be awesome!
Dragon21
Dragon21
1,309
2,920
Raleigh, NC
emailed them today and they asked for pictures.
I just took it off and saw that the nut in the bottom of the winch appears to be stripped. The bolt that fell out i found and it has the threads from the nut on it.
Reactions: JTW
13,394
65,489
KFI Mount?
I found when I mounted mine, I needed longer bolts in either the front or rear 2 holes. Had barely any engagement of threads due to the mount being doubled up.
Reactions: Dragon21 and JTW
KFI Mount?
Mine needed the same with the emp mount
Dragon21
Dragon21
1,309
2,920
Raleigh, NC
KFI Mount?
Yea, I replaced the 2 that were too short. I think they were the ones in the back though. Those stayed in fine.
Dragon21
Dragon21
1,309
2,920
Raleigh, NC
Got my warn winch in... new bolts, tightening them down and the last one i did stripped. didnt even wrench on it hard.... ugh the frustration.
did get my skid plate in yesterday though, and my highlifter lift should be here today.
IMG 93461
Dragon21
Dragon21
1,309
2,920
Raleigh, NC
installed highlifter lift last night, piece of cake. Started on the skid plates. Gotta drill, tap, and mount the outside of the center section and do the front section then that will be done. Winch should be here today so hopefully i can get that behind me and put my bumper back on too
Reactions: JTW
Dragon21
Dragon21
1,309
2,920
Raleigh, NC
next on the list... tires and front fox shocks...
I wanted to do Blackwater evos, but do too much pavement. So gonna be 28x10 roctane or 28x10 Motoclaw.
All thats gotta wait a while though. Just hope to have it before takeover
Reactions: CumminsPusher
208,014
What brand of skids are those?
Dragon21
Dragon21
1,309
2,920
Raleigh, NC
wiped some of the dust off and went for a short ride. Also go the wife to drive it. She wasn't a fan of this one as much as the 700. Learning the gas pedal is a little harder when going slow.
IMG 9619
Reactions: pct
Dragon21
Dragon21
1,309
2,920
Raleigh, NC
Got my Tusk Warthog tires in yesterday and mounted today. They are 29” tall. We’re measuring just over 28” when they were mounted. Inflated them to max psi to help stretch them. Will air them down to around 10-11 tomorrow. Gonna have to get spacers since the rears might run at full drop with the Highlifter lift
F4F257F6 24D5 4776 AD7E B061B78DD1C6
A225FE59 62FD 400C 9A9C 46A0708414C7 E4F03AC7 02CF 44B3 9AE6 955CF6F224A2 21093DB8 74B1 4AE2 90E5 E38FFAEB3320 1FD581DA 35BD 46DB AE90 46F06518E7F8
Dragon21
Dragon21
1,309
2,920
Raleigh, NC
Got my wheel spacers on. 1” super atv on all 4 corners. Decided to take it for a quick spin and thought it was gonna rip my skid plate off. Was rubbing bad. So tried to heat it up and bend it, but I’m impatient so I cut it off. Should be good now.
E15B80A2 6598 4B45 812F EE86C8560EEE 146D6342 2B15 4A1F 8FA1 5F8DED91DF9C 09018996 207C 4FAF BB1C 63DE8DBCC939 58B26496 217A 44D1 B5E3 B28496ECFDFE 8F300033 8DEC 4378 B5FE CEE90F67A29D CD6C29EA 8DB3 4BB8 AA08 D3D22734C225 6F17404C 3D80 4F18 8D29 1825EEB1A602 B8B8E79A 5E8A 4BC2 9C97 24A089C93357 735CE491 B0EA 4C10 9DCC D4AAF53A1B35
Dragon21
Dragon21
1,309
2,920
Raleigh, NC
got my light bar hooked up this weekend
Reactions: Eltobgi
