P1000 Driving tips beyond the owners manual
Ridinfool
Ridinfool
36,145
386,039
Western North Carolina
I get it!
just when theres an oil type or brand question, the thread usually blows up like Hiroshima 🤣
theres so many opinions on this its like presenting a bill to congress for a debate lol. If u use the search, it will blow your mind🤯🥳
Here is a start, without seeing your bottle of oil u used, as long as it said suitable for wet clutches, your prob ok. Im not gonna tell u what Ive used in my 3 rigs starting in 16’ cuz I dont want to start a dumpster fire 🤣🔥🔥🚒
Shoot me a pm if u really want to know!
I’m disappointed 🙄
Ridinfool
Ridinfool
36,145
386,039
I just changed my sub transmission oil and I used Mobil 1 racing 4t advanced full synthetic 10w40 motorcycle oil what’s your thoughts on that but I used Honda oil in the engine
I’ve found that the best oil is the slippery kind…
I tried using the oil outta the fryer at my local McDonalds and seemed like anyone behind me started craving French fries…
Also if you do use the oil from the fryer, make sure you strain it first.
Good luck. 👍
105,256
Good luck. 👍
Oh ok if u insist!
5-40 Rotella T6 in all 3 rigs since 16’ and Im in the single digits.
He dosnt hit the “like” on our posts. Must be too loosy goosy for his kind 🤷‍♂️
NoMo fo so!
5,023
22,429
that HP4M, do you all use 10w30 or 10w40? I ride in all temperature ranges from down in the single digits and teens up to 100 or more degrees.
First off - when Remington says it has to be wet clutch compatible, he's talking about the engine and DCT oil. I'm talking about the subtransmission - it doesn't need its oil to be wet clutch compatible and that's why several of us are running the HP4 with Moly in the subtrans only.
30 or 40 weight - your choice. Since you ride year round and the subtrans only gets changed every once in a while (don't remember), pick the weight you're comfortable with. If most of your miles are in hot temps, run 40w, cold temps, run 30w. When I'm running 40w, I give it longer to warm up in cold weather. Same with engine oil, if it's cold and I'm running 10w-40, I give it longer to warm up.
Also note that nothing is spinning in the subtrans when you're warming up your engine, don't take off like a bat outta hell, give it a mile(?) to warm up especially in colder temps.
Don't put gear oil in the subtrans (80w-90), it wasn't engineered for that and won't like it. Some have and will recommend it, I won't.
Ridinfool
Ridinfool
36,145
386,039
NoMo fo so!
I know right…🙄
Give a guy solid advice you’d think they’d hit the like button for helping them out… especially that part about straining the fryer oil first… you won’t find that in any owners manual that’s fer sure.
105,256
I know right…🙄
Yup top secrete snippets like that are invaluable right there with mixin Ketchup and Mayo! 🥳
AndyC
AndyC
34
88
USA
I’m gonna get that HP4M for the sub. Whatever is in it now is what the dealer did on that initial 100 mile service. I always use 10w-30 or 10w-40 gn4 in the motor.
5,023
22,429
Check the fluid level before you drain it, I know of 2 Talons that were delivered 1/3 low. :mad: I doubt the dealer did anything with the subtrans since its mtce interval is a year or two (don't remember).
AndyC
AndyC
34
88
USA
I’ve checked it 2-3 times in the last 1500 miles I’ve put on it since the initial service and it’s always right on the money. I know the book says before every ride, but that seemed excessive to me. Especially since I “ride” mine every day 7 days a week for farm work.
RedorDead
84
475
USA
Yeah, that’s just lawyers writing CYA stuff. I check oil periodically depending on operating conditions. Usually every 2-3 tanks of fuel. Pulling the dipstick every day would just be an invitation to get dirt in the engine.
DRZRon1
DRZRon1
850
2,734
lol - engine oil check - periodic
Transfer case - if there ain’t oil on the floor or blowing out seal - hardly ever - unless u believe aliens may me involved
Dirtstiffs-1000
Dirtstiffs-1000
1,554
5,658
hondasxs.com
Mobil 1 4T Racing Synthetic in the motor too.
Dirtstiffs-1000
Dirtstiffs-1000
1,554
5,658
hondasxs.com
