how would you use your dual battery to boost for starting in cold weather
I have the isolator hooked already,so basically I just need +to + to an emergency bypass switch In cab?Not knowing how your system is connected. If you do not already have a backup bypass switch in place, you could just use jumper cables between your 2 batteries. Positive to Positive, negative to negative, essentially turning them into a parallel battery system.
Here is an example of what I have been drawing up for mine, when It gets warm enough to work on. No, it is not complete, it is a work in progress, and still missing a bunch of things. The emergency bypass is on the bottom, and all it does is connect both batteries together.
Have a good day
I see Rayger143 posted as I was typing
Yes. But this shouldn't be common.I have the isolator hooked already,so basically I just need +to + to an emergency bypass switch In cab?
Why wouldn’t I want this to a switch in the cab to use when needed, I wouldn’t need it often but when I’m out and it’s 20 below it would be nice to throw a switch if needed?Yes. But this shouldn't be common.
Did you have a leftover wire from the isolator install? Thrown that in your glove box. If ever needed. Just place it on the isolator post to jump it.
Didn't say you couldn't install one. I said it should not be common to need it.Why wouldn’t I want this to a switch in the cab to use when needed, I wouldn’t need it often but when I’m out and it’s 20 below it would be nice to throw a switch if needed?
I don’t think I’d need it very often, but if I did a switch would be nice in ND weather👍🏻Didn't say you couldn't install one. I said it should not be common to need it.
If your primary battery is letting you down, it wont be long before your second does as well.
Just adds more wiring to what many have as a over complicated dual battery setup already.
You are definitely right on wire conglomeration, I think I will add 2 more though,we have winter 6 months here!I don’t think I’d need it very often, but if I did a switch would be nice in ND weather👍🏻
You're likely to melt that small wire gauge if used for jumping, too many starting amps.So I wired SAE Charging cable ports to each battery individually so I could charge one or the other and (if Isolator goes gunny), but really just intended to add power ports for misc. 12 volt doo- dads we use while riding.
The collateral outcome was I also made an SAE cable I can plug into both ports to tie the batteries (jump) together, if necessary.
YMMV
If the isolator were to wig out, all you'd need to do is jump the two posts on the isolator while charging one battery. No real need to have charging cable ports on both batteries. But, hey, to each their own.So I wired SAE Charging cable ports to each battery individually so I could charge one or the other and (if Isolator goes gunny),
Have you considered upgrading your main battery? Or have you done this?I don’t think I’d need it very often, but if I did a switch would be nice in ND weather👍🏻
While access jacks (12V DC outlet) is handy (I have one as shown below), they are not usually wired with heavy enough cable for the potential current demand for jump starting a battery. As an example, 12 ga wire is typically used for up to 20 -25 amps. That'll be fine for trickle charging a battery or wiring a big LED light bar, but nothing close to adequate for jump starting. Shown in pic, I have my outside aux plug wired with 8 ga, as I want to use it to run an air compressor as well as a convenient trickle charge port. The single port charges both batteries through the True isolator.So I wired SAE Charging cable ports to each battery individually so I could charge one or the other and (if Isolator goes gunny), but really just intended to add power ports for misc. 12 volt doo- dads we use while riding.
YMMV
main battery is good but when it gets cold I just want some insurance I can use the aux I have too!Have you considered upgrading your main battery? Or have you done this?
I beg to differ here, when the wind is blowin 20 and its -20 doing anything outside can be a real ******.I'd much rather run 2 short heavy wires to a shut off switch. up here thats more important then a lot of other accessories.I hope I never have to use it, but if I do I'll know I'll be out of the wind trying to start it.I can see how this would be overkill to most of you, but not this old guy. thanks for the input guys, its always appreciatedWhile access jacks (12V DC outlet) is handy (I have one as shown below), they are not usually wired with heavy enough cable for the potential current demand for jump starting a battery. As an example, 12 ga wire is typically used for up to 20 -25 amps. That'll be fine for trickle charging a battery or wiring a big LED light bar, but nothing close to adequate for jump starting. Shown in pic, I have my outside aux plug wired with 8 ga, as I want to use it to run an air compressor as well as a convenient trickle charge port. The single port charges both batteries through the True isolator.
My preference for jumping is to do as Hondasxs suggested, Make a short jumper to connect the two big terminals on the True isolator - - done. Okay, why not put a shorting (jumper) switch on the dash? One reason is it won't get used much and takes up space you might want to use for other accessories. Another, perhaps more practical reason, is you cannot put that kind of current through a common rocker switch, so you will have to use either a remote heavy duty relay, or install your big switch on the dash with heavy cable going to that switch - doable, but none of the options for dash mounting seem worth the trouble to me when a short cable with two clips will do the deed with ease, if lacking a bit in finesse.
