P1000 duel volt meter install location
Jas sxs
Jas sxs
137
525
rankin county ms
good after noon my dash switch panel is out of room full of switch's and radio on my PK1-5 any one else have some other mounting places ?
pictures please
Reactions: Buggyman and Lady01
Lady01
Lady01
192
487
Midland Michigan
pictures please
Switch housing in the club store...
1652386807140
bumperm
bumperm
1,848
6,641
Gardnerville, NV
Yeah, I put mine in a spot I haven't seen anyone else use, it faces the driver as well. The little momentary push button underneath the voltmeter applies a momentary ground so you can check both voltages without turning on ignition. This spot was relatively easy to wire to from under the hood, as I did it before removing the big warning label panel and installing radio etc. (which of course made access to work on other wiring much easier - - should have done that first.
20211221 215040
Jas sxs
Jas sxs
137
525
rankin county ms
Thank you that something I haven't thought about
13,333
64,754
I have a spare dash in my shop. I will take some pics tonight for you.
Right by the key has some room, but not much hand access.
If you go to the left of the column, you can remove the cupholder for better access.
bumperm
bumperm
1,848
6,641
Gardnerville, NV
If you pull the cover below the steering wheel it gives access to either side of the steering wheel.
For newbies, there should oughta be a thread devoted to access and best practices for running wires etc. I've done most all I need to do, but I often struggle mightily, only to later find a much easier way to do what, sadly, I've already done.
Reactions: sharp
Y
Yakman
126
313
WA
pictures please
pictures please
There's some room on the left of the steering wheel and its easy to access from behind with the fender removed.
20220516 124706
Reactions: Lady01
Y
Yakman
126
313
WA
?? For that location rear access, why not remove the cup holder? Would that be easier than removing the fender? I haven't removed a fender yet, so don't know how easy that is.
Fender isn't hard. Just push pins and door removal. Cup holder might work but you have more room from the inside of fender. Bottom line is whatever works best for you.
Jas sxs
Jas sxs
137
525
rankin county ms
that's a awesome idea I am just starting add my electric stuff , I like getting tips from people who have been there done that and figured it out .
Wyoming307
Wyoming307
12
60
Wyoming
Removing the fender flare is easy and allows a lot of access
Reactions: Lady01
