BOX1
P500 EMP vs OEM Hard Top
Upstater
Upstater
22
61
Upstate NY
Slayer
I have the EMP poly and it works great for my needs. Everything previously mentioned is correct. There is no space above/behind the roll cage with the EMP but I like it that way. I don't run any windscreen or rear panels so I can't tell you about the fit. I believe EMP states they design then to fit with their windshields as well as the OEM options. The install is easy, essentially a plasti-dipped hose clamp type material that has kept it snug with no squeaks or vibrations. At least none that I notice and bother me. I don't think you can go wrong with either as long as it fits your needs for other accessories and the height etc. The price won out for me.
whitebear
whitebear
20
41
Marana, AZ
Getting ready to pull the trigger on a 500 this week. The only dealer option i am considering is the factory hard top. I think it will either be that or order an EMP poly hard top. Have searched the forum and cant really find much on the EMP. Those of you with a poly hard top, which do you prefer and why?
New 2019 , just installed EMP poly roof and Hard coat full windshield. was worried about being too hot in the AZ sun but it lets enough air by without being blasted with hot air, plus it is easy to remove if needed. Put on four Kenda Mastodon HT Radials 26x9-12 on four ITP Delta Steel Wheels, 12x7 5+2 rims. Ride is much smoother and looks wise, much better. Great Forum , my new hobby is lots of fun and costly. Back rack is last mod for a while. Eager to hit the trails.
Front side
New Tires
Mudder
Mudder
NTC Ambassador of Walls
11,201
82,724
Like the lower profile of that new roof.
BOX2
box3
