P1000 Engine Code 29 IACV Connector
cwalton
cwalton
Who has more fun!
334
724
West Virginia
Sometimes I get a check engine code of 2 long and 9 short blinks. Does anyone have an idea of what this means?
snuffnwhisky
snuffnwhisky
Village Idiot
3,303
18,152
Cullman, AL
  2. Other Brand
IACV circuit malfunction . Rough idling
29-1 . Loose or poor contact of the IACV connector 4-25 . IACV or its circuit malfunction
Reactions: Eltobgi and pct
snuffnwhisky
snuffnwhisky
Village Idiot
3,303
18,152
Cullman, AL
  2. Other Brand
Capture
Neohio
Neohio
Beast of the East
13,328
64,705
Painesville Ohio
@cwalton
Consider joining our club as a lifetime member, we have a pdf of the service manual available. I believe the membership is discounted until year end.
Reactions: joeymt33 and pct
cwalton
cwalton
Who has more fun!
334
724
West Virginia
@cwalton
Thanks for the advice Neohio, I think I just became a lifetime member.
Reactions: pct
cwalton
cwalton
Who has more fun!
334
724
West Virginia
Where is the pdf of the service manual located?
Reactions: pct
Neohio
Neohio
Beast of the East
13,328
64,705
Painesville Ohio
@cwalton I tagged you in the thread.
cwalton
cwalton
Who has more fun!
334
724
West Virginia
I am not very good at maneuvering around this forum, so if that helps, thanks. Thank you and Snuff for all your help. Next job will be digging into the buggy and figuring out the code issue.
cwalton
cwalton
Who has more fun!
334
724
West Virginia
101 0735 101 0735 101 0734 101 0733 I have found broken wires going to the IACV connector. I dont know what these connectors are called to begin finding new pins and crimp tool. Can anyone help?
Reactions: Eltobgi
Neohio
Neohio
Beast of the East
13,328
64,705
Painesville Ohio
I had the a website saved that sold pins and pliers.
If you into my profile and find the thread i started about fuel injectors, i may have posted it there.
If not, i will check my pc at work tomorrow and see if i still have it saved.
cwalton
cwalton
Who has more fun!
334
724
West Virginia
Did not see website info for pins on your thread about injector issues. Did i read it correctly when you said Honda may want to change harness for bad plugs?
Neohio
Neohio
Beast of the East
13,328
64,705
Painesville Ohio
Correct, the proper repair according to my dealer is replace entire harness. My dealer was zero help on my issue due to diagnosing it myself.
Edit, hit up ebay and look at used harness pictures to see if you can find a cheaper harness to rob connectors from. Africa twin should have an iacv valve. Might be able to buy a small section and replace entire plug.
Edit 2.
Here is the connector in the club store
Neohio
Neohio
Beast of the East
13,328
64,705
Painesville Ohio
Pins should be universal across many lines from same manufacturer. Wouldn’t hurt to have 10-20 spare pins and seals for future use.
Neohio
Neohio
Beast of the East
13,328
64,705
Painesville Ohio
Hopefully you caught my 2nd edit above with this link
208,011
I believe they are called molex pins, should be able to get remove and install tools for the housing.
208,011
That is a cool site, think @cwalton needs the Yazaki 1.5 system. Go to By application/use and pick the connector.
We used to have a electronics store local that you could walk into and get anything. It was great.
cwalton
cwalton
Who has more fun!
334
724
West Virginia
I have already sent pics to tech support.
