EPS
JimH1
JimH1
59
102
Duluth MN
Well today was the first time I try the 4xdiff lock and when it lock up the eps quit working is this normal?
I had to take it out of the dif-lock an shut it off when I started it back up I had power steering. Has anyone else had this happen?
Delton
Delton
Honda Fanboy
9,967
31,488
Middle TN
No that is not normal. Steering is harder in diff lock, that's normal. But you shouldn't completely lose power steering. Have you driven a vehicle with diff lock before? To a first timer they might think they lost it due to increased steering effort.
drfubar
drfubar
TheDonFather
5,889
19,242
Mary's Ridge (Dayton Mtn), TN
Probably just how it feels when locked in 4wheel. It really gets stiff
322,675
Was the light on or did I just feel differently? Like the others said if it was just feel that's normal however. If I remember right the 1000 does give a little more power to the steering in diff but you still feel it.
JimH1
JimH1
59
102
Duluth MN
No the light came on with an exclamation mark next to it.
322,675
Ok unless you were using lots of power just prior like winching or something then that's not normal. Imo just keep an eye on it and hope it was a glitch.
JimH1
JimH1
59
102
Duluth MN
Well I just went for a short ride and when i got to my drive way I put in 4-lock this time it went into lock with out any trouble and no issue with the power steering in fact the steering didn't change at all.
Reactions: CumminsPusher
322,675
I heard somewhere about the system giving more power in diff mode so I'm wondering if there was just a hiccup the first time going into diff. Just keep your eye on it but I think you're going to be good.
