P700 Erratic idle
Hopey
Alberta
Unloaded the 700 Pioneer out of the trailer the other day and washed it. When I was done I started it and went to put it in the garage and noticed that the idle would go up and down. There was no issue before I washed it. Anyone else have this issue or an idea where I may start looking?
I stored my 700 in a 40’ container for a period at a job site, humidity in the container stayed about 100% because it had some leaks.
I had to dielectric grease all my electrical connections because they’d started to corrode.
Maybe you got water in a connection somewhere around the engine?
swsebek
swsebek
2,854
5,835
pa
Also if you cleaned the filter and didn't get off all the water or Cleaner it will. If the filter is dirty it will surge a little at Idle
Reactions: BobRack
