P500 Exhaust is on the way
Skullmonkey
Skullmonkey
26
31
Southern Ohio
After seeing that email does anybody have any other brand names they'd suggest?
jak9922
jak9922
hot headed wopolock
3,283
5,636
pittstown ny
the p5 is not getting support from the aftermarket at all thats y im out to show them they are missing out even tho they are getting my money for other models they are missing out on a good market
Reactions: JJ7429 and ehart814
ehart814
ehart814
1,701
3,889
NWPA
And you're doing a great job, by the way.
There is a really reputable exhaust builder located near me. He does really great work. I am keeping an eye out for a slip on pipe I could use with a quiet core insert for when hunting season comes. Whenever I get around to getting a pipe, I'm going to see what those guys would charge me to fab it up for me.
Oh another thing, sometime do you think you could check your afr's again since the pipe is on there? I'd like to know if the pipe leaned it out excessively. The P500 has the closed loop efi, so I would think it would be able to compensate at least a little bit.
jak9922
jak9922
hot headed wopolock
3,283
5,636
pittstown ny
i have to get my hands on the meter again but ill try and its definitely not to lean i pushed it hard and no lean backfiring or skipping
Reactions: ehart814
wyliechief
wyliechief
11
9
Rosamond, CA
Gonna have to try this mod. Been wanting more power and better sound for a while. Just have to find someone who can weld.
Thanks for posting jak!
jak9922
jak9922
hot headed wopolock
3,283
5,636
pittstown ny
fuel mapping is different which is why dobeck had the afr for the p5 and not the ejk so im not sure if it would work
jak9922
jak9922
hot headed wopolock
3,283
5,636
pittstown ny
most definitely could be wrong so don't quote me
jak9922
jak9922
hot headed wopolock
3,283
5,636
pittstown ny
plugs will be the same but its the settings inside with different resistence for the app like take for instrance my 250l I have the ejk but when I but the 305bbk on it I have to send the ejk back to dobeck to get reflashed to support the 305 but seeing how the p5 and foreman use the same motor justr different ecu mapping I don't know if that will effect how it will work lol make any sence
Reactions: JJ7429
maddmax
257
231
Clarksdale Ms.
yea thanks
jak9922
jak9922
hot headed wopolock
3,283
5,636
pittstown ny
but hell give it a shot its easy enough worst that will happen is it will just like a bag of sh!t for a few seconds so then shut her down and take it off in curious about that now as well
jak9922
jak9922
hot headed wopolock
3,283
5,636
pittstown ny
to bad we went closer id shoot over and try it out on mine
