P1000 Fabric Mid Panel/Hard Roof Gap?
W
wbyman22
WI
Just finished installing a soft Honda mid panel and full Hard roof on my P 1-5 along with 2 piece hard coat windshield. Any of you guys running the same set up? Just curious on the gap between top of mid panel and roof? Driving down the road there is quite a vacuum and the wind somehow swirls around and blows a lot of air into cab area from that gap, concerned that when it gets good and dry, that gap will carry a lot of dust with it? Anybody block that gap with anything in particular that worked well?
Reactions: Isaiah
Pool noodle.
Elkhunter
Elkhunter
345
453
Minnesota
2nd on the pool noodle! Also if you can find a bigger dia. Foam pipe insulation
weelad
weelad
85
583
83
West Michigan
Cant believe the air rushing over the rop bar so took advise from above and ordered 3.5 inch foam to fill the gap. Had to trim some on the outsides as the foam was hard but seals up nice and is waterproof for washing inside
NOODL
