P1000 Fairlead on stock P1000 bumper??
Boss0144
137
147
Commerce Township, MI
I was taking my plow off of my machine today and noticed that I caused some damage!
My fairlead was split in half (lower half missing), and my bumper just below the fairlead was split in two! The spot on my plow where the winch attaches was also bent upward.
The last time I plowed, it was super wet heavy snow. And there was an icy snow bank at the top of my drive that I fought my way thru as well. All that I can imagine is that the loading was more that it could take. It looks like maybe the fairlead broke, and then the rope split the thin piece of bumper below it. I find it hard to believe, but I don't have another explanation. The snow was so heavy that I was spinning all 4 in 4 low. I backed up, and raised the plow thinking I was lessening the load. In hindsight, having the plow hanging in the air by the rope and ramming in to the super heavy snow might have been the cause of my issues.
ANYWAY, in the short term, I'm just going to put a replacement fairlead on there so I can use the winch before figuring out a plan to fix, or more likely, replace the bumper.
I was looking at this as a cheap fix:
I came home today, so the machine is 200 miles away. Anyone know if this will fit the mount on the front? I have a Warn Vantage 4000 winch. I looked at their page, but it doesn't give any dimensions for their fairlead. And it's more than twice the cost of this one.
Looks like this one is 6" between the fasteners. In my head, that's too small. But I'm not sure.
I'd appreciate any help you can give!
Thanks.
Hondoman
Hondoman
727
1,697
Texas
That's the one I have, 6" is the correct spacing for the p1k.
Hondoman
Hondoman
727
1,697
Texas
Boss0144
137
147
Great! Thanks! Looks like you have the KFI 2" receiver too? How do you like that?? I was considering it to use to push my pontoon boat in to my barn so I could have a better look at what I'm doing as I try to tuck it in real close to the wall. I wasn't too concerned with the going in, but using it to pull it back out concerned me a bit. The boat is close to 4k lbs. I'm concerned that I'll hurt the clutches trying to ease it out. My dealer actually told me not to worry about it, if you can believe that. But a few stories of burnt clutches stuck int he mud in reverse has me a little concerned.
Thanks for answering my original question Hondoman!!
Reactions: Hondoman
Hondoman
Hondoman
727
1,697
Texas
I originally bought the kfi 2" adapter for a 100lb road feeder. I've since moved it to the rear because it blocks the headlights on the front. I really only use it for a recovery point, but it does work well.
Boss0144
137
147
Ok, thanks.
I got my new fairlead ordered last night. Thanks again for that.
Reactions: Hondoman
