P1000 Falling out of gear.
A
Alumapro
10
Alberta canada
Got a 2016 1000-5. This machine is awesome! Love it in every aspect. Have driven many other brands and I must say, for the type of riding/driving and usage I do, it is the best. However...one problem has arisen. If I'm in 4 low or 4 diff lock, say in a mud hole or going up a steep incline with the winch in use. Once I rocker the winch switch the transmission slips out of gear into neutral! As soon as I let off the winch rocker it immediately jumps back into gear! Not very useful in a sticky situation I must say. A small engine mechanic I know suggest I add a second battery. He has ran Honda's most of his life and seems to have found they lack the electrical capacity to run most of their electrical shifting on many models. Not too sure how the DCT works if it is controlled electrically or what? If so, I'll probably add a second battery. Has anyone else had this problem or have any thought?
272,156
It definitely could be electrical, the winch drawing so much it drops out. Haven't heard of it happening to anyone else but certainly is a possibility.
A
Alumapro
10
Alberta canada
I'm definitely open to ideas and this seems to be the most congruent. It's still on warranty, but id rather not waste the dealers time. (Small shop with 2 employees) also a nice guy. He used to be the wrench at this particular shop before taking over. If you have any other ideas please feel free to let me know! Only info I've had on the dual batteries is wire in parallel and use an isolator. Preferably solid state with a low voltage cut out.
272,156
I would try a second battery in parallel on hand just to test if it stays in gear. If it does then do it properly. Here is my setup:
P1000 - Jackal's P1000-5
A
Alumapro
10
Alberta canada
This is an awesome install! I'll definitely look into it more I detail! I'll keep the li k for when I figure mine out. Two banks of six rockers eh? I like it. That instLl would put some of the avionics installers I known to shame. Very nice.
L
Logan
69
146
Canada
It is 100% a low voltage condition. You need a second battery, and it needs to be isolated. I have gone through this already.
pmward
pmward
136
303
Galena, Missouri
How did you ground the winch? I am running Warn 4500, single battery, and do not experience this. Will be adding second battery soon, but I'll bet it's the winch wiring.
Could be a weak battery. I also think the grounds should be checked. Check the ground on the battery, under the seat and engine. I'll look for a picture of the locations.
Reactions: CumminsPusher
6981e3d1479495615dd848152ad2865d
Winch ground must run all the way back to the engine.
I know that's what the instructions say but many of us did not do that. I grounded mine to the auxiliary battery which is under the hood.
7a68813738bcafb0c81e150c5b1740a7
My auxiliary battery is grounded straight to the OEM battery and grounded to the frame.
pmward
pmward
136
303
Galena, Missouri
Joey, I think I see an isolator in line with your aux battery. In this case, winching will never effect current to engine/transmission. When running single battery, the ground to the engine for the winch is important. By the way, nice work under the hood.
pmward
pmward
136
303
Galena, Missouri
And by the way, I was born and raised in Anniston.
Reactions: joeymt33
Good eyes! And thanks for compliment but that was a year and half ago. It's now dusty, muddy, and more wires. Looks not near as good. I wanted the winch to pull a little bit stronger. The Odyssey battery would drop under 11 V when winching hard. I added a second solenoid that is activated when the winch is active. The second solenoid is on the far right side and it connects the two batteries but only while the winch is active. That's an older picture and does not show the second solenoid, let me find a more recent picture.....
E9cbef4c2e37acb5e75aedf7e0a9b847
I lived in oxford for a few years so we may have been neighbors. '95-2000.
Anyway, the isolator is a great idea. All my accessories are separate from the OEM electrical system. Only the winch will allow them to be connected below 12.7v but I've got dual volt meters to monitor the batts.
One other thing, I can't take credit for many of my mods. A lot of them come from this forum.
Reactions: ohanacreek
"Hondasxs.com, we don't come up with many of the ideas you use, we make them better.......then rip them off for ourselves"
A
Alumapro
10
Alberta canada
It was dealer installed proline to pickup. Apparently I need to do some more digging around to be sure. Same setup as you
Josepht85
5
Ellisville, Ms
Joey, what's is your secondary battery hold down made out of. How to you have it mounted. Thanks
I bent piece of metal to fit over the battery. One side slides into a cut out I made....
D8b635885458513c75558ef3143e4e99
The other side is bolted down...
1703870bea828a1110955e6d592cdce9
