P500 Feeling A Bit Tipsy - Kenda HTR vs Big Horn 2.0?
KyGal83
KyGal83
8,880
87,817
Kentucky
Lately I have been feeling more tipsy in my buggy. I wasn’t sure if it was do to an issue with shocks, riding more challenging obstacles or my tire/wheel setup. I am leaning (pun intended) toward it being... wheel/tire setup. I wanted to test out that theory... luckily I have a good friend willing to indulge me in an experiment. @futzin is a good friend and neighbor with a P500 (Critter) also, and I have pretty much followed the same mods he has to my P500 (Dingleberry). So we have swapped out our wheel/tires to test out. Here are the original setup details:
Critter's - Kenda Bearclaw HTRs (Front)27x9-12 and (Rear) 27x11-12 both on ITP Steelies with a 4+3 offset
Dingleberry's - Big Horn 2.0s (Front) 27x9-12 and (Rear) 27x11-12 both on ITP Steelies with a 5+2 offset
Anyone running either of these setups, let me know your thoughts please.
So those are now in reverse. I want to point outother than the noticeable tread pattern difference, the HTRs have a more square profile and the BH2.0s are more round, HTRs are an 8 ply tire and the BH2.0s are a 6 ply.
AND another difference that has irritated me since they arrive and were mounted... The BH2.0s do not measure a true 27! The HTRs do. Here is a side by side to show the difference in height.. the BH2.0 barely measure above 25.
8F45C539 53E3 47D5 924D 372538357A98
The Swap:
1C3835FD 19E8 44DE 816A 7860FE99D1DB
ONE OF THESE THINGS IS NOT LIKE THE OTHER:
AF9640B2 90FA 4DAB 991B 88D21EAA952F
A4CBA2EE 0B57 4A88 843E 83D61FD2D60C
66B4F36B 668C 4D3F A2C3 37BC4459A775
65993D6D 3761 496D 9AD6 705998D3A816
FB3D3DA8 C2F4 4261 82E0 AE2C00EA1E31
8A11F2B3 AA97 4FD6 AEBC 8684EB8D2BD7
E4D53AAE A598 4396 B4E8 127D3447EDC6
D2375080 9B82 4159 905D C882EF19EC57
323A6C97 54C0 498E 9E49 40960EF9E1B2
P
pappyo
597
2,400
Have used both: Adirondack Mts.N.Y.
BH 2.0 's <> 27X9X12 FT. <> 27X11X12 REAR 6ply. <> 4x3 offset <> 7.0 PSI <>. Nice ride & OK Traction
KB HTR 's <> 27x9x12 Ft. <> 27x11x12 Rear 8ply <> 5x2 offset <>7.0 PSI. <> Better Ride & Better Traction
Benifits:
True measure
8ply
Nice Ride
Excellent Traction <> most conditions
Both work well for trail riding - mild mud & rock <> Prefer the KB ÷HTR
Now for a 3rd. Option:
ITP XTR's 1-1/8th Lug
same size as both above 27's <> 6ply <> measure 26-1/2 <> 7PSI <> 4X3 offset
Decent Ride
Better Traction in Mud & Rock ( than BH2.0 or KB HTR )
20200725 123146 20220529 140946 20210607 082430
Mopower58
Mopower58
CST is the Best!
79,455
706,365
Crystal Springs,Ms.
The 4+3 on futzin's sxs will have more track width than your 5+2. Same air pressure? You could add 1 inch wheel spacers to make the track width the same, his tires being 8 ply would be less tipsy than your 6 ply.
178,016
The Swap:
View attachment 356421View attachment 356422View attachment 356424View attachment 356423View attachment 356425View attachment 356426View attachment 356428View attachment 356429 View attachment 356427
What's strange about this is that you're saying the 27" BH's don't measure true height. I originally bought 26" BH 2.0's and they measured 26 1/2" actual. Now I'm running 28" BH 2.0's and they measure 28 1/8" actual. Wondering why those 27's are so short.
BTW, I'm running 5+2's with 1" spacers on back, just to even the track width, and it's pretty stable. The 28's are 10" wide though but you wouldn't think it would make that much difference. Interesting....🤔
futzin
futzin
4,129
30,680
Kentucky
My personal impressions from this swap:
-the BHs are lighter (no surprise there)
-the BHs provide a more comfortable ride (very noticeable)
-the BHs tend to push in turns on dirt and gravel, and I'm just more confident in my HTRs for traction
-the BHs make my buggy feel less stable. Likely a combination of weight, wheel offset difference, tire profile, and 6 ply.
My takeaway:
-For my purposes (to maximize trail capability, within reason) I'd again choose the HTRs over the BHs for Critter.
It's really nice to be able to readily compare/contrast differences in our buggies. Another example: @KYgal83 Tusk power steering has a noticeably heavier feel than my EZ Steer.
KyGal83
KyGal83
8,880
87,817
Kentucky
You are correct. They have been measured by 3 different people with the same results.. I am starting to think what I have are 26”s misstamped as 27”’s. Going to call BH about it.
Splorin
305
863
Maine
I've mentioned in the past that some BHs are 'adult' sizes. The 27s always look puny especially next to 29s at a CanAm dealership on similar machines. They do look 4" shorter. 26x11s look all of 26. Those 28x10s look real. If running 7" rims I'd run the 11s on all fours......
JCart
JCart
895
2,020
Kamloops, BC Canada.
Thanks for the comparison and thoughts. On my P500 I run HTRs sized 27x11x12s on 5-2 rims on all corners, typically with 6-7 psi air pressure. Rides and handles (I think great), what I do notice is the front tires seem to last longer and I do rotate front to back periodically. Steering effort is not much different than 9” wide fronts. No difference now with E steering…. Notice radials ride way nicer and have more traction than previous bias ply tires. Are the 4-3s compared to 5-2s noticeably more stable?
Thanks again for this thread.
j
KyGal83
KyGal83
8,880
87,817
Kentucky
j
I did not think the offset would make a difference but I do notice it. I will be going to the 4+3s regardless of what I do about tires.
We have completed several rides now so I will do an update sometime this weekend. Also been talking with Big Horn about the size inconsistency.
Mopower58
Mopower58
CST is the Best!
79,455
706,365
Crystal Springs,Ms.
I did not think the offset would make a difference but I do notice it. I will be going to the 4+3s regarding of what I do about tires.
We have did several rides now so I will do an update sometime this weekend. Also been talking with Big Horn about the size inconsistency.
"have did"? 😂
