P500 First oil change
Hondap5
Hondap5
20
58
Monroe nc
My wife’s 2020 is due for its first service. Plan on using a Honda filter and rotella t6 which I’ve been running in my 17 rubicon. Was looking for opinions. Is this oil okay to Use in her 500 as well?
801DCF88 8B24 4060 BD86 59A7B8A7D974 0FB9B99F 2B13 44C6 8AC3 7D628E1DC51D
Fatsquatch
Fatsquatch
Approved Member
121,618
1,013,852
Hidden
View attachment 228476 View attachment 228477
I've seen several others on here using rotella t6. The key is wet clutch application. JASO MA is what I see referenced as the thing to look for. I'm not the expert on the topic though.
BURNDOG
BURNDOG
84
229
Oregon
I been using blue Lucas in the recon. Probably use it in the p500🤷‍♂️
NitroxDiver
NitroxDiver
488
918
Concord NC
I am running T4 in my machine. I had been running the Valvoline full synthetic but it was consuming it quite fast. I switched to the T4 a few weeks ago and can’t believe how much quieter the machine is and the oil consumption has stopped. I’m sure the T6 will be fine I just never used it. I would not use the T5 synthetic blend as it does not list JASO MA on the jug.
Hondap5
Hondap5
20
58
Monroe nc
The t6 is jaso MA oil so I’ll probably just use that. Just wanted to make sure it was okay.
Reactions: NitroxDiver
NitroxDiver
NitroxDiver
488
918
Concord NC
Let us know how it does after about 1,000 miles or so. I’m curious if you have any oil consumption or not with the full synthetic. Not saying you will have any consumption just curious how the T6 compares to the Valvoline full synthetic.
nctrailboss
nctrailboss
440
1,454
north carolina
T-6 is good stuff.It will be fine for the wet clutch in the P-5.
Reactions: Hondap5
