I was quoted 557.00 for the service, I asked them why so high and was told they check all the fluids change oil and do a valve adjustment.Around here they are going to hit you up for about 100 bucks maybe More in FL.
25 for oil
10 for filter
45 hour for the service
20 for oil disposal
And you have to take it there.
Can be done for 30 bucks by yourself and it's pretty easy
Wow that's insanely high. I had my dealer do my valves at 1300 miles and I paid 285 for them to tell me it was in specs. I just did itself thanks to the great detailed valve adjustment guides on this sight and it was free and costed me a torque wrench I bought and 2 hours taking my time.I was quoted 557.00 for the service, I asked them why so high and was told they check all the fluids change oil and do a valve adjustment.
If you are comfortable changing oil I say go do it. If the valve check is above your comfort level, either send it to the dealer, or find a local member to walk you thru it.Wow that's insanely high. I had my dealer do my valves at 1300 miles and I paid 285 for them to tell me it was in specs. I just did itself thanks to the great detailed valve adjustment guides on this sight and it was free and costed me a torque wrench I bought and 2 hours taking my time.
A lot of us guys are not mechanics on here but We can't pay 500 bucks for something as easy as checking things out. These machines appear to be complex and tricky but once you pop off the plastics and read the helpful detailed advise of the others who post their how toos. It's actually very common sense and easy stuff that makes you kick yourself for having paid a dealer to do what you could do all along.If you ever changed you car oil then this is piece of cake.
I agree the price is nuts. I’m going to change the oil myself check all the fluid levels and ride. Oh and call the dealer and cancel my appointment.Wow that's insanely high. I had my dealer do my valves at 1300 miles and I paid 285 for them to tell me it was in specs. I just did itself thanks to the great detailed valve adjustment guides on this sight and it was free and costed me a torque wrench I bought and 2 hours taking my time.
Have you seen any of the “how to” guides on the site? I’m happy to leave you the links if you haven’t found them yet. That quote seems ridiculously high for what they’ll actually do. And honestly you’ll probably do a better job than they will!
Thank you Sir !WANTED, REWARD. - How-to's |Bounty List!
Scroll down to the “completed” list and go to the 700 section. There are how tos for the oil change, cv boot replacement, and front and rear diff oil. There are two on valve adjustment but they aren’t linked at that page, here they are-
P700 - Pioneer 700 Valve Adjustment Guide
P700 - Adjusting valves
There you go, that’s everything you need to know it’s just up to you if you want to tackle it
Funny. I just called yesterday on mine it's nearly $700 with the valve adjustment as well.I was quoted 557.00 for the service, I asked them why so high and was told they check all the fluids change oil and do a valve adjustment.
They must be charging the majority of the costs toward the valve adjustment, which takes less than 30 minutes if you've done it before. And that's actually adjusting the two valves. If the valves are in spec then I'm sure you would be charged anyway.Funny. I just called yesterday on mine it's nearly $700 with the valve adjustment as well.
1st love the Tradorus pic. Yes, they said it was the extra cost for the valves. I’m thinking about doing it myself.They must be charging the majority of the costs toward the valve adjustment, which takes less than 30 minutes if you've done it before. And that's actually adjusting the two valves. If the valves are in spec then I'm sure you would be charged anyway.
