Fox shock leaking oil
DAJO
182
125
Indiana, Arizona
Walking around Talon up on trailer looking at the fox numbers on the springs wondering if numbers can be crossed over to actual spring rates.
Noticed left rear shock has oil on the rod where it comes out of the shock body. The other three are completely dry. Haven't heard much about leaking Fox shocks. Will wipe it clean and observe for more oil.
If I have to pursue warranty do they replace shock or try to replaced seals.
Reactions: sharp and BWAF
Ragnar406
Ragnar406
The Great Bald One
4,447
17,022
Bella Vista, AR
As for the numbers on the springs - yes usually you can google the numbers and find out the weight of the spring.
Reactions: CumminsPusher
snuffnwhisky
snuffnwhisky
Village Idiot
3,303
18,152
Cullman, AL
  2. Other Brand
They would normally replace the shock. They should not leak at all unless wore.
DAJO
182
125
Indiana, Arizona
Spent a lot of time on the internet trying to find spec on Fox springs using the numbers stamped on the springs.
Not finding much useful. Anyone know where this information can be found?
snuffnwhisky
snuffnwhisky
Village Idiot
3,303
18,152
Cullman, AL
  2. Other Brand
The OEM springs are usually stamped for an OEM part number. The aftermarket springs are stamped according to their length, diameter and rate. You will probably have to call Fox or Honda to get the specifics. Seems like I saw them listed on FB at one time.
Ragnar406
Ragnar406
The Great Bald One
4,447
17,022
Bella Vista, AR
What are the numbers?
DAJO
182
125
Indiana, Arizona
top front 039-00-451-8 top rear 039-00-452-8
bottom 039-00-453-8 bottom 039-00-454-8
DAJO
182
125
Indiana, Arizona
Called Fox and they said oil may be makeup oil so I will clear it off and watch.
spring rates Top front 350 Bottom front 225 Top rear 250 Bottom rear 250
dankathyc
20
20
hurricane ut
Did these numbers get truly written as intended? Seems the top should always be lighter than bottoms and fronts should be lighter than rears. Very interested in this as I want to make some changes but not sure what I really have for stock springs.
