P1000 Fox Shocks - Bushing Replacement
Ragnar406
Ragnar406
The Great Bald One
4,450
17,033
Bella Vista, AR
Anyone change out their bushings on the eyelets of their fox shocks yet? I noticed this weekend i have a lot of play in mine to the point that it is time. would rather buy and service myself if possible and not have to send off to Fox
Edit to add : found how to order down below
115,818
Not yet, but I’d like to know where to buy them?
Ragnar406
Ragnar406
The Great Bald One
4,450
17,033
Bella Vista, AR
OK folks, I have figured it out - if you are looking to get the Bushing for your Fox Shocks that you bought aftermarket you can go to the parts lookup for an LE model and they sell all the parts off of that
This one is from Rock mountain ATV
1596204619525
1596204898079
there are different parts for the front and the rear shocks or (cushions as they list them) and make sure you pick the ones for your model 5 seat or 3 seat .
Note it is about $50 is parts for each shock. $210 for all the components for front and back.
On backorder until Aug 10 so once it arrives i will post up here what i learn about replacing them .
Ragnar406
Ragnar406
The Great Bald One
4,450
17,033
Bella Vista, AR
Well I have a slight update -
Still waiting on my original order as everything is still back ordered however ....
My Right Front shock bottom bushing was done and with a trip coming up to Moab I was looking everywhere to try and find a replacement. Just so happened that when @ohanacreek had to rebuild one of his shocks he ordered an extra set from Weller racing. now he had sold his shocks to @BWAF and included that extra Bushing set with them... So i called @BWAF up Sunday and he was more than happy to put them in the mail so that I could receive them Wed - since I leave for my trip tomorrow....
So here are some pics from the install
Here are all the pieces that you need - if you compare them to the blow out diagram above you can pick out which is which
IMG 7506
here is a pic of one side showing the order they go in.
IMG 7508
Now the toughest part of this whole process is that little metal band that is wrapped around the cylinder...replacing it
You should be able to take a socket that is as close to the same diameter as the band in and using a press or a vice push out the metal band .... I ended up having to cut the band with a hacksaw blade to remove it ... this is actually where my bushing was wore the most.
if you look below I believe this picture is after i pushed the old band out.
IMG 7509
now next you want to push the new band in - I did this using a socket and a vice
Band pushed in - you kind of have to play with the depth to get it right.
IMG 7510
Next comes what i think are alignment spacers maybe - One side slipped right in and the other had a little help with smooth jaws on vice.
IMG 7511
After both of those were installed I finished off installing the cylinder and the side UHMW washers and my shock was back to being tight
Neohio
Neohio
Beast of the East
17,743
85,594
Painesville Ohio
Would you mind sharing pics of old components?
Does the large steel bushing show any where?
Could one simply replace the oiltite bushing and dust seals and call it good?
Reactions: BWAF and Mudwing
Ragnar406
Ragnar406
The Great Bald One
4,450
17,033
Bella Vista, AR
Let me see if i still ahve tonight - I should but yes there was wear on the steel bushing... it looked like the Band (think you saying this is the Oiltite bushing) was pressed out at the top and there was wear on the steel bushing from that.
I'll see if i still have an can add pics.
Neohio
Neohio
Beast of the East
17,743
85,594
Painesville Ohio
Yes, the band/bushing you pressed in looks like oil impregnated bronze aka oiltite.
I guess we don't need pics if you are confirming the large steel bushing had wear.
