P1000 Frame crossmember bent
E
Ericthered
Eric The Red
271
522
Sparks, NV
I constantly smash sage brush. (no way around it). So I want to minimize the holes for brush to enter hot area of engine. Last trip my passengers were sure we were on fire. Burning dust smelled pretty bad. Don't want to start a range fire, so what's the best option? I will probably never bash too many rocks, just bushes. Will have to see the plastic ones to see if they are strong enough. Once I see the prices I will replace the pitiful factory with a new one.
Reactions: BWAF
ToddACimer
ToddACimer
Pioneer 1005-2
3,685
15,587
Oshkosh, Wi
I've found with grass, leaves and brush (and even mud and rocks) they will always get above skid plates and into crevices. I'd rather have holes for washing it out and on this machine for venting heat than trying to completely seal it up.
Reactions: BWAF and ohanacreek
208,730
Run a high speed front mount brush hog????????????? HA!
Reactions: BWAF
Kane1000
Kane1000
22
104
Eastern Iowa
Here is what we did to 3 machines, the cross members were all but touching the motor. We pulled them back down and welded 1" square tube 3/16" wall in the crossmember. We also added a 3rd removable crossmember in front of the transmission.
I saw in @ToddACimer post about his bent crossmember and his adding an additional brace. I pulled my skids to get ready for my trip to royal blue in a few days and found mine were also bent/bowed. I used my truck as an anchor and my lift to bow them back. I have 1/2" uhmw skid plate covering the entire bottom similar to his 3/8". I don't have any impressive stories or pictures of his stump escapade to go with it either. I can't recall being hung up on anything. I'm wondering if alot of guys are seeing this same issue?
I have some 1" square SS tubing leftover as well as 1" schedule 40 black pipe, but the clearances under the engine are tight for additional bracing.
I'm looking for ideas and this place is the greatest for that.
I'll be checking mine when I get back from Royal blue and see how bad it looks again.
View attachment 85155 View attachment 85156 View attachment 85157
20180413 154103 20180413 154106 20180413 154113 20180413 154116
ToddACimer
ToddACimer
Pioneer 1005-2
3,685
15,587
Oshkosh, Wi
Firemedic530
Firemedic530
387
1,133
West Jefferson, Ohio
I went ahead and welded the 1" square tubing I had into the cross members and added 1 in front of the sub trans. I left the bottom open on the 2 I added so the water and dirt will drain. It's stainless steel and also 3/16" wall thickness. I went ahead and welded the extra as well because it's easy to cut out if necessary.
I found out the P1K5 sits comfortably on the tailgate also.
20180908 152306 20180908 152251 20180908 142634
Reactions: pct, JTW and BWAF
View attachment 86322 View attachment 86323 View attachment 86324
You needed stainless to the frame??
Reactions: BWAF
ToddACimer
ToddACimer
Pioneer 1005-2
3,685
15,587
Oshkosh, Wi
Stainless wouldn't have been my first choice of material either. It's very difficult to create a structural weld joint between stainless and mild steel since the 2 materials require such a difference in temperature to weld. If you really used 3/16" stainless it's unlikely you welded the joint properly without overheating the thin frame crossmembers and creating a brittle joint. Likewise if you welded into the frame crossmember you probably don't have much for penetration in the stainless. Steel tubing would have been a better choice but that's just my opinion.
Reactions: pct, BWAF and JTW
I really didn’t think they would stick together.
Reactions: BWAF
Firemedic530
Firemedic530
387
1,133
I concentrated the heat on the ss and then feathered into the frame. I wouldn't have bought ss to do this project, but I had it. I've mixed metals on other projects with good results and figured that at least the new pieces wouldn't rust. Lol
My frame was surprisingly still straight after going up dragons back twice and down widowmaker once. We slid on the skid plate quite a bit. I figured while it was apart for cleaning I'd go ahead and give it a little more strength.
I was surprised at how much rust is starting to show around the stock welds and in the tubing. I rattle canned everything with rust converting primer and then paint. I know it was a waste of time, but I felt better. I'm going to be cleaning this deep at least 2-3 times a year.
Reactions: JTW and BWAF
L
LarryAmboy
904
2,010
Castalian Springs, Tennessee
It’s too bad that someone hasn’t come out with a one piece chrome moly frame that you could replace the stock frame with.
Reactions: BWAF
208,730
Looks good!
Reactions: BWAF
Baldeagle
73
AB
I'm running 1/2 inch skids and usually use the belly while crossing logs, thanks for the heads up!
If you build your own out of 1/2 UHMW you can build the middle section out of a single piece and limit the number of holes for stuff to get in and catch. Make sure you extend the plate a couple inches outside the frame on each side. Then build your side plates, they will go above the center plate rest against the side of the frame. Also extend the side plates an inch or so outside the tube rub rails. That way when you are going around a tree, rock or other obstacle the skid plate transfers the force directly to the frame and not onto the small mounting bolts. Mine works great and use it in very rough terrain. A good idea if you are building your own is to not use self tapping screws where you are adding bolt but to use rivnuts. Have fun.
ToddACimer
ToddACimer
Pioneer 1005-2
3,685
15,587
Oshkosh, Wi
I welded my frame gussets in a few weeks back. I used the RuffStuff tube gussets. They are formed 3/16" steel and sold in 4ft lengths. You need 2 27" pieces so you'll have to buy 2.
104078 1c28fd34530d0d10bb2417e1e9ed46c3
Test fitting the material, really nice fit.
106784 f9cf3d243deb44de6cd72b24a16f2cb1
4 post lift makes the job a bit easier. The paint finish isn't perfect since I was in a bit of a hurry but the skid plate mounts to them anyway. I did pre-paint and mask the gussets before welding so the insides are painted but obviously a bit of paint got burned off in the welding process.
Stood up
Img 20190216 132527 jpg
Img 20190216 145724 jpg
These are the pieces cut to length and clamped in place
Img 20190209 083355 jpg
Welded and paint roughed up. I also have a 3rd crossmember
Img 20190216 141553 jpg
Painted. Good enough for the abuse it's going to take
Img 20190216 145556 jpg
I'd call it flush with the bottom of the frame so it wont add any bow to my 3/8" UHMW skid plate
Img 20190217 102648 jpg
Reactions: Superthrill and JTW
Stood up
I went to order some but the $20 shipping pissed me off and I closed the window
