P700 Front Caliper Sticking
Gb63
Gb63
29
50
Mississippi
Hey all....Has anybody had to change front calipers or rebuild them. One of mine is sticking on occasion. Just trying to find the best out. Honda wants like $300 a piece for theirs....
Alan_Vander
Alan_Vander
1,547
2,752
rosepine,la
take it off pop the cylinder out clean it up put it back in if no scarring. i use a hydraulic shop around me to swap the seals out. i dont know if we have a rebuild kit for these or not.
Sent from my E6910 using Tapatalk
Reactions: Gb63 and Mudwing
HEK
7
12
Avery,Tx
My 2017 right front was sticking at 3453 miles/430 hrs.Got a full set of Niche for about $47 at Walmart.com.Put 1276 miles on them so far.Problem was slide pins were mostly dry. I removed small nicks with Scotch-brite,put some brake lube on pins and the rest is history
Gb63
Gb63
29
50
Mississippi
I pulled the calipers and greased the pins and slide contact areas. Also worked the piston in and out a few times. No sticking as of now...we'll see how long it last....
MikeG
MikeG
359
2,478
Baton Rouge LA.
Well, caliper started sticking again. I removed it and tried to work it free with c clamp and air...seized up. Replaced with new one$$$$.....all is good now.
Mine was sticking and I just rebuilt it.
DRZRon1
DRZRon1
1,456
4,440
Anybody have any rebuild kit part numbers?
go on Ron ayers, partzilla, motorsport - etc. - search under the oem parts if you choose to go down that road - I think a set of seals is $10 and if you change both pins, maybe another $15, imo - id get it apart and see what you need - probably just a good cleaning and a new set of seals is all that is needed - ive not seen many bad pistons but anything is possible
