How do you do to lock the front differential with the p5 ?With Rincon or Rubicon using the front brakes but with the p5, this is not possible. Do you have a solution?
From my understanding there isn't enough room for the extended axle or diff.after looking at the parts diagrams for several honda machines it looks like the Big Red MUV700 has the same front diff but with a locker on it. the part numbers are the same for everything except the right output of the diff. does anyone have a measurement of how far out the 700 diff sticks past the main housing? i am still looking for a way to lock the front diff this would make a big difference on what my machine would do. the ring and pinion ratio is different too. the Big red is 45/13 and the P500 is 53/13. it looks like the diff could be swapped by changing the ring and pinion and making a custom front axle or just extending the a arm..
X 2If you pull it off you'll be a hero in the 500 world. I hope you do it!!
X3!!
Let us know!! If it works, I'll follow suit!!Looking at the top a arms they are offset to the rear of the machine if I swap sides that will bring the top of the spindle forward. I am looking for the locker first to see if it needs to be repositioned or if stock a arms will work with stock axles.
When are you going to do this. And when you do would you please post pics along the way??thats why i was hoping someone had one so i could get a measurement. my plan is to add a locker of some type and probably change the a arms. if you look at the axle shafts they go toward the rear of the machine i was going to flip them around to move the front hubs forward to allow for larger tires without a lift. currently i am running 27" swamp lites and i get a small amount of tire rub at full steering lock and when i am off camber. i saw where high lifter has made arched a arms for the P1000 that move the front hubs forward a couple of inches.
Have you already removed the sway bar?i dont know yet but i am willing to try something out to get a locker and bigger tires. i dont do a lot of high speed riding so as long as the steering tracks straight i think it will be ok. most of the trails i ride are 2nd or 3rd gear. going to L for really rough spots or deep mud. last weekend i tried to climb up a ravine, the left rear tire completely disappeared in a hole, the right front was probably a foot off the ground and spinning, the left front wasnt doing anything. i think with a locker i could have pulled on through and climbed out of the ravine. it did back right out with no problem and i was able to find a way around it.
I had a Kinq quad 700 back in the day and, I believe, the reverse caster was an issue with them. It actually made the steering easier but also made it so that when hitting something the wrong way, it would actually jerk the handle bars away from you..someone described it as having a shopping cart with the front wheels actually reversed from the way they are now...I found that very helpful. After 4800 miles I'll admit it only happened once but scared the crap out of me-LOLI wonder how it would handle reversing the "caster" ?
I have removed the sway bar and the rear stays planted a lot better but I am looking for traction help from the front. I thought about the spool but I haven't found one that fits yet. I appreciate all of the feedback that's why I posted on here. I want to hear concerns from everyone and past experience with similar issues.
