I'm having the same problem did you ever find a solution for yours mine brand new barely 50 miles on it gas gauge always shows full I really don't feel like taking it to the dealership and leaving it there for a week but mine's under warranty did you get a solution?New P5 fuel gauge worked just fine. Have about 350 miles on it now, and the gauge says I'm not using fuel, it stays on full.....love the idea, but wish the gauge actually worked.
Anyone have an idea on how I could troubleshoot this dilemma?
No, never found a real solution. More than 2 gallons used before it shows down one bar, and then the gauge drops quickly...I'm getting used to this abnormality.I'm having the same problem did you ever find a solution for yours mine brand new barely 50 miles on it gas gauge always shows full I really don't feel like taking it to the dealership and leaving it there for a week but mine's under warranty did you get a solution?
Mine does the same.No, never found a real solution. More than 2 gallons used before it shows down one bar, and then the gauge drops quickly...I'm getting used to this abnormality.
Same for my machine but I also find I can fit a lot more than 5 gallons in my tank.No, never found a real solution. More than 2 gallons used before it shows down one bar, and then the gauge drops quickly...I'm getting used to this abnormality.
I have a 2020 p1000 that started showing always full. How do you unplug the fuel pump and sensor? Did it work?I have a 2021 pioneer 1000 deluxe. The fuel gauge stopped working within the warranty period. I live in Ohio, but spend the winters in Tucson, Arizona. Musselman's Honda in Tucson was very helpful in getting this fixed under warranty. 2 years later, I'm out in Tucson, and now the fuel gauge is not working again. It is $204 for the part. I don't know what labor would be. I'm going out and disconnecting the fuel pump and fuel sensor and plug it back in to see if that helps.
While I'm one of those who thinks ethanol sucks donkey dik, no matter how much a float might swell up, there's no way that can make it read full all the time. Pull the pump assembly, turn the key on, and run the float arm through its travel; if that doesn't show varying fuel levels, then that rheostat/resistor is defective. I'd have no problem believing that ethanol killed the electrics though.It may be the ethanol in the fuel.
Fuel Gauge Inaccuracy Due to Ethanol
ethanol fuel messing up Gas Tank sending unit??? - Offshoreonly.com
General Q & A - ethanol fuel messing up Gas Tank sending unit??? - I have a 388 Hustler that the fuel gauge is reading high, I am guessing that maybe the ethanol has made the float in the gas tank swell or made it more buoyancy and making the gauge read high. Could this cause that? I'm guessing...www.offshoreonly.com
u r a smart techWhile I'm one of those who thinks ethanol sucks donkey dik, no matter how much a float might swell up, there's no way that can make it read full all the time. Pull the pump assembly, turn the key on, and run the float arm through its travel; if that doesn't show varying fuel levels, then that rheostat/resistor is defective. I'd have no problem believing that ethanol killed the electrics though.
It has something to do with the float contacts, from what I am told.While I'm one of those who thinks ethanol sucks donkey dik, no matter how much a float might swell up, there's no way that can make it read full all the time. Pull the pump assembly, turn the key on, and run the float arm through its travel; if that doesn't show varying fuel levels, then that rheostat/resistor is defective. I'd have no problem believing that ethanol killed the electrics though.
