I
I wanted to share what I did to address the "problem" with the gas pedal location on my 1000-5. The change resulted in getting the pedal to a MUCH more comfortable location and eliminated leg fatigue. It also made throttle management a breeze, no more jerky starts at low speeds on rough ground!
It was as simple as this:
Hope this helps for anyone else that may be looking for an option.
- Remove brake pedal
- Remove gas pedal
- Use angle grinder to cut two 1/4" "reliefs" - one on the back side of the pedal shaft, and one on the front near the pedal itself. Be careful when making the cuts not to go all the way through, the idea is to notch it and then bend the pedal shaft to close the gaps created from the cuts.
- Weld pedal shaft where cuts were made and re-install.
