P1000 Intermittent gas smell
  • Thread starter Bombardier Convert
  • Start date
Y
Yakman
128
315
WA
Due to the many and repeated reports of water in the P1K gas tank caused by the low stock vent location, you should be extending that vent high on the cage anyway. It might not stop the fuel smell but it WILL stop getting water in the tank. And it will probably stop the smell too.
Ok Thank you! I will do that!
Where are most folks extending the gas vent line to? Wondering if theres a way to get it into the ROPS up high...
Y
Yakman
128
315
WA
Check out my post on page one of this tread.
I don't go in deep water so I don't need to extend anything except the gas line to get rid of the vapors. I already ordered the tubing I was just wondering where everyone is extending the gas line vent to.
Hillbillytnt
Hillbillytnt
557
2,047
Ky
I just ran mine up to the top. Zip tied to the cage. Just don’t collapse the tubing. The kits usually come with a cap/filter. So you may think about that. I don’t take mine swimming either but the lines that end under the seat were just a bit to close to the splash zone so I extended most of the others.
115,792
Kinda like when your butt stinks?
Dam dog!
1658195456836
115,792
Curious . . . is that a demo of "Intelligent two paw drive"? And will his rear overheat?
Yes and Yes.
Also wanted to know what was the largest size tire he could put on stock wheels and not rub down below
