Anyone know what would cause my extended gas vent line to drip gas? It is extended up to top of roll cage. Thanks
All my vents were extended to the roof by the dealer. After I installed a rear panel I can smell the fumes a little from time to time. The only time I had it drip was because I overfilled the gas tank, and it has to go somewhere.
good point, I had just filled mine up. going to see what happens after I ride some more.All my vents were extended to the roof by the dealer. After I installed a rear panel I can smell the fumes a little from time to time. The only time I had it drip was because I overfilled the gas tank, and it has to go somewhere.
Keep us informed if it stops.Seems I had a low spot in line under the passenger seat . I tightened the line up , so far so good....
