P500 Gator's P5
Reactions: Bastardchild
RoadGator916
RoadGator916
54
108
MinneSNOWta
Forgot to list my box on the interior mods!!! I’m still working on installing some of my stuff but it should be ready soon
76609A2E 70F9 409D 86D7 EE22382B6ACF
6A2A044F FE50 4CC4 987E CEB5C047C329
6DC0AF71 48EF 4BB1 B6AE F48EA8A83800
71F07DCC AD6E 4BC7 ADF6 6F755BEAD9B7
5EF41B52 A73B 45E6 95A9 15287D2612CC
2429FE7A 7D94 4F68 8B31 75843BA33B33
6606B4A5 3E37 49E1 82AE 6A43301FD7EE C1122129 344C 45A6 AC45 D8EFC8C6C15C
Nashby
Nashby
75
285
83644
Reactions: rtn001
103,611
What did you keep in the big box and did it ever feel top heavy?? The seats are definitely cool.
Reactions: rtn001
RoadGator916
RoadGator916
54
108
MinneSNOWta
I put all my Ice Fishing supplies inside there. Made it tall enough I could put 5 gallon with tip up inside the bucket. I never had any issues with the bike being top heavy. At least I never noticed it. Keep in mind I wasn't riding on trails with it only going across the lake.
11,321
84,119
A good multi-purpose machine with the P500 rear rack, versus a permanent dump bed on other models.
Reactions: Nashby and trigger
RoadGator916
RoadGator916
54
108
MinneSNOWta
Winch is installed and it actually works. I changed out the switch and added it to the dash. I’m going to instal the cord plug under the dash on the drivers side. Need to buy a 1 1/8 hole saw first! And some pics of my Bluetooth stereo from Boss. It is made for Motorcycles but I modified it to work with a volume switch installed next to the 12v plug!
69BAE06C EF5F 4D2B B1D4 0827A7828B50 52EE138B C00D 45C6 8655 3A56FDD677A7 9F9419B9 3995 4F6B A05E B1B05B8B7002 D229226E 318F 4F7A B715 DA061B89844C
Reactions: rtn001 and 100Acre
RoadGator916
RoadGator916
54
108
MinneSNOWta
49ED6663 F175 4C8E A5EF 4D3E70BE4844
BB1F64C6 ADFB 4E9F A526 AE64FAD0E85C
5BDFA47D F5C0 46FF BE37 9B6BF22681FC
1B3553F0 97D5 4564 9A98 9C0B723CCDBE
5A1742BD 8D77 436F 88CA 62B9C48F41FE
My rear bench seat is mounted!!! I still may have a friend weld up a support for the foot rest just to make it more stable. I am not a light person bout 225# and it didn’t move much when I stepped on it.
I used 2 u bolt to fasten it on. I had to add a piece of 3/4” plywood under it to level is out where the metal was under the seat. I also modified one of the unused angle iron pieces to give the u bolts more stability.
Seatbelts for my kids so they don’t mess around while putting around the campgrounds.
I can still use the hitch too with the 1 1/4- 2” coupler. Just don’t want to put to much weight in it or things could bend. (I have a tow dolly I can use if I have to move a heavy trailer!). 557317C2 DD57 4D0E 9403 6C174332591C
RoadGator916
RoadGator916
54
108
MinneSNOWta
BB8A3D32 3F99 40FF 8629 5532E985B833
668D0373 3C55 44DA 80F8 F8D67CB1ACF5
25259900 DA93 4B6D A9C6 370E5975DABB
63C27845 737D 4E50 BDDD F38D26F044F6
34714D02 BBAD 40B7 9ED3 67ABD213FE3A
Heater is installed! I have to refill the coolant and hook up a couple wires tomorrow then test the heater. It definitely takes up some room under the hood but that is to be expected. The vents look nice and give it a nice factory look.
Just have to cross my fingers I installed everything correctly and it works when I test it in the next couple days.
RoadGator916
RoadGator916
54
108
MinneSNOWta
For the most part it was very easy to install. The kit comes with everything you need event the hole saws. The most difficult part was cutting the radiator hoses and putting the Y connections in to the heater. The electrical is simple and over all the instructions are very detailed.
RoadGator916
RoadGator916
54
108
MinneSNOWta
Very simple to remove. 6 bolts hold it on. Simple to take off only take about 5 mins.
Reactions: rtn001
RoadGator916
RoadGator916
54
108
MinneSNOWta
8D10F381 0627 4A4F 8F7B AF942C17C507
Added a small box behind the rear seat and my version of a Trigger shield (had a chunk of 60 mil rubber laying around). Also added a rear view mirror so I can keep an eye on the kiddos when they are riding on the back.
E9F3CFCA 79E4 4C1B 8520 3717702CE5DE
6530C41B A4B6 4714 A5E5 853C9F415C14
I’m still battling with the Ice Crusher Heater trying to get it to throw heat. I had it going for a bit but now it isn’t again. I will have to mess with it again tomorrow to get it pumping heat. B33B2305 191D 4077 8251 FBAAC46B606A
Reactions: rtn001 and trigger
