P500 Gear reduction reversed
William
William
1,442
2,887
Flowood MS
If people are getting gear reductions to lower gearing ratio, couldn’t people that want a faster top end get a kit made to increase gear ratio? I know it would rob bottom end power but low is extremely low anyway... just a thought.... opinions?
FYI I don’t want it, just thinking bc I have seen a lot of people wanting it...
ToddACimer
ToddACimer
Pioneer 1005-2
3,564
14,633
Oshkosh, Wi
Slightly bigger tires would be easier and you'd have more ground clearance too. Assuming the engine can pull the taller effective gear ratio of the new tires you'd be able to go faster
William
William
1,442
2,887
Flowood MS
I have bigger tires, it slowed it down...
HUCK
HUCK
1,047
2,315
ARIZONA
Have a friend who put 30s on and increased top speed by 5mph .
NitroxDiver
NitroxDiver
488
918
Concord NC
If your bigger tires slowed it down it means your engine doesn't have the power to turn them. Bigger tires would be almost the same thing as higher gearing. So if the tires didn't work for you gears will not work. How big are the tires?
William
William
1,442
2,887
Flowood MS
Well the added weight from tires is the only difference... the gear increase wouldn’t add weight... I had mudlite xtrs which measured out to 28” and were heavy... could only hit 38 on flat ground. now I have 27” zillas and can hit 42 again. Like I said, I don’t care it was just a thought for people who wanted more top end... maybe even portals with higher gears instead of lower... that wouldn’t be cost effective though...
Reactions: NitroxDiver
hondabob
1,162
4,538
Prescott Valley, AZ
Most 27's clear. My top speed is 46 mph with 30's but I can't use full lock and I also trimmed the frame ends a bit. You lose a bit on accel but it pulls the 30's ok in 5th gear. I recommend 27's.
906UP
906UP
13,114
122,425
da Yoop
I'd be happy with just a taller 5th gear, even if it wouldn't "pull" it maxed out it'd be nice to be able to cruise at 25-30mph without it sounding like it's coming apart. If I can't get this thing to quiet down it'll get traded in the spring, I've made good progress but damn.....sounds like a bucket of bolts above 25mph!
