BrotherNov
I'm installing an Axon 55S on a tough country bumper. Looks pretty easy, but a couple of basic questions. First, I've seen a lot of pics of peoples under the hood setups (while figuring out the dual battery stuff) and I don't recall seeing where winch wires enter the battery area Did you guys drill a hole though the under-hood area to get the cables to the battery? I assume you had to, where did you decide was best? Is there a more "elegant" way to get them up there? Second, I attached a pic of the entire wiring instructions. Simple enough, but I want to clarify something. The wire in between the switch and the remote harness looks like it's going to a keyed power source (where it says "wire splice not included). Can I just ignore/delete this wire since I'm running it to my second battery and prefer it to run without the key being turned on?
