P700 go to air filter.......
livefromthetree
livefromthetree
466
1,309
Mount Vernon Indiana
Do y’all clean and re oil the Honda filter or replace each time ?
I've been cleaning mine and the oil change kit I get comes with a filter, so I have several stored. Have a change coming up this weekend and will replace it for the 1st time just because. 2400 or so miles now
Mudwing
Mudwing
36,959
306,563
The Mud holes
Clean and re oil. You have to use the PJ1 cleaner. Keep a spare filter ready to swap as the filter needs time to dry before oiling. There is another way to oil is use No-Toil which is actually not oil. But you need to clean every molecule of oil off before using that and you can’t mix the two. 😎
livefromthetree
livefromthetree
466
1,309
Hey @Mudwing
I changed the oil over weekend and in process replaced the air filter and used PJ1 for the 1st time. Basically I used a new pre-oiled filter (comes with the kit I buy) and sprayed it down with the PJ1 and reinstalled. When I first tried to start, it hesitated and chugged and turned off. After a couple of tries it started fine. I rode it yesterday and it may be my imagination, but it seems like it is running a little rough.
Reading your reply makes me wonder if I was supposed to clean the oil off the new filter before hitting it with the PJ1 and if that's why it feels a little rough or sluggish.
Pic just because :cool:
20210718 112039
Reactions: Kinlaw and Mudwing
Mudwing
Mudwing
36,959
306,563
The Mud holes
Hey @Mudwing
It’s a good question. We’ve been back and forth about oiling the new filter before. @DG Rider has been the resident tester for oiling filters. I don’t know if over oiling is your issue but I had my engine cut out due to a dirty filter. Have you checked your valves yet?
livefromthetree
livefromthetree
466
1,309
No, I am almost mechanical enough to change the oil and filter...almost :p. I didnt even think about the valves since it was only sluggish after changing the air filter. Actually thinking back, it was fine when starting between oil level and leak checks after changing the oil. I changed the air filter after all of that and then it started choking out.
I ran it about 30 miles last eve and it started right up and ran without issue, but it just seems like it's rougher.
Mudwing
Mudwing
36,959
306,563
The Mud holes
I would run it. Clean the other filter per instructions then swap it out. See if that changes. Maybe you’re ultra tuned in and it’s in your head.
Reactions: livefromthetree
livefromthetree
livefromthetree
466
1,309
Good plan, I have a few filters ready to go, will just swap back to the yellow and see if my head clears up 🤪. Hell I never even thought about switching the filter out to see if that helps. Damn alkyhol
  • Haha
Mudwing
Mudwing
36,959
306,563
The Mud holes
All hood in the hood. That’s what the forum is for. 😎🤣
  • Haha
41,785
For sure I would oil the new Honda filters based on what I've seen...
I typically oil in in a zip lock bag since I usually use the liquid stuff. I over oil it, squeeze it, and then leave it in the bag out of the bottom. It can take a few hours to stop dripping.
I haven't used aerosol in a while, so I don't remember what it's like, but certainly, throwing the filter on right away using my way (without letting it drip) could choke a machine down.
livefromthetree
livefromthetree
466
1,309
Thx DG. The filters that come with my oil change kits are oily already, do they need more than what's there?
